Old 03-23-2024, 06:22 AM
Rockman413 Rockman413 is offline
Default Batch rename disk file name too?
Hi there,
I know how to batch rename the audio clips (at the right) displayed inside the right column.
But after renaming the disk file remained the same too. Wondering if there's a way to batch rename the clips and disk file? I think I remember seeing an option of renaming both the clip name and disk file name but now it's gone?
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt
Old 03-23-2024, 07:32 AM
JingleDjango JingleDjango is offline
Default Re: Batch rename disk file name too?
I don't think this has ever been possible as a batch operation within Pro Tools. The option to rename disk files as well has only ever been available in the classic 'Rename Clip' dialog.
It would be nice to have that option, yes.
Old 03-23-2024, 08:32 AM
moogboy100 moogboy100 is offline
I've used SoundFlow to rename the audio files the same as the clip name after I do batch renames.
But it just now occurs to me, one could use SoundFlow to pull this off like a native PT shortcut, i.e.:
  1. Remove the native key shortcut for batch rename in PT's kybd shortcut options
  2. Assign that keyboard command to a SoundFlow script that:
    1. Opens the batch rename window and waits for it to close
    2. Then renames the all the selected clip's audio files
🖥️ Pro Tools Ultimate 2023.12.1 | Mac Studio M1 Max (64 GB) | Ventura 13.5.2 | Focusrite Red 4Pre
💻 Pro Tools Ultimate 2024.3.1 | MacBook Pro M3 Pro (18 GB) | Sonoma 14.4.1
Old 03-23-2024, 11:59 AM
BScout BScout is offline
Originally Posted by Rockman413 View Post
Hi there,
This has been asked for since even before "batch clip rename" came out.
And Avid has ignored us though multiple users have pointed out the easy way to avoid/warn a user if they are going to give 2 files the same name in the same folder. (This is the scenario they say is the reason for no "batch file rename")
So currently you first "batch clip rename" and then immediately hit the key combo for "file/clip rename" and just keep hitting enter until all the files you had selected are done.
That transfers the clip name to the file if the selected is a file.
It's tedious and a waste of time when Avid could give us many ways to make this a single stroke but what we have to do until Avid gets it together and listens. (this is what Soundflow is doing too)
Old 03-23-2024, 06:24 PM
So like open the rename and rename one audio clip and repeat it for a certain times?
Old 03-27-2024, 07:13 AM
+1 for a tick box for Rename Disk File in the Batch Clip Rename function!
Scott Gatteño
Old 03-30-2024, 09:37 AM
Yes. I've long used a simple SoundFlow script where, after I do a batch rename, I trigger the script, it counts the number of selected tracks, then does the standard Rename Clip that BScout mentioned, it does it for however many times as the number of tracks were selected.
I've since made the script I mentioned previously, which I may share later to the SoundFlow forum. Now my SF overrides PT's key command for batch clip rename, and it handles the file renaming - and whats even cooler about it is it is using Pro Tools new SDK/API so the file renaming happens invisibly (you dont see the clip rename popup X number of times).
How to batch rename the audio file/region names? Rockman413 Pro Tools 2019 4 10-08-2021 11:56 AM
Rename disk file for committed tracks abt Pro Tools 12 0 08-27-2017 04:02 PM
Unable to rename disk file googs macOS 0 08-21-2012 12:16 PM
PT 8.0.3 and cs1 Unable to Rename Disk File JB3 Pro Tools TDM Systems (Mac) 3 06-14-2010 02:44 PM
Batch rename file types? jonnyrocker Pro Tools TDM Systems (Mac) 4 04-22-2006 03:17 PM
