Old 03-19-2023, 02:44 AM
milesofwire milesofwire is offline
Default 192 isn’t being seen.
G5 2.5 GHz, Pro Tools 8 doesn’t see the 192 I/O.
I hear a click come from the interface and get the message that the I/O can’t be seen.
This is when DAE is loading.
Anyone know what could possibly be wrong?
Old 03-19-2023, 04:22 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: 192 isn’t being seen.
Dirty or broken digilink cable. Run digitest and see if it says everything is okay with your card(s).
Janne
Old 03-19-2023, 06:46 AM
Ran DigiTest and everything passed.
Old 03-19-2023, 07:28 AM
K Roche's Avatar
K Roche K Roche is online now
See if the 192 is showing in Mac Sound and in Audio Midi Set Up
Or Try holding down the N key while launching PT and see if the 192 shows as a selection ...
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 03-19-2023, 09:31 AM
Yes the Digidesign hardware shows up in Audio MIDI Setup.
And when I hold “N” down on startup I get a screen where I can adjust the number of voices and sample rate.
When I select a sample rate the interface changes accordingly.
Not sure where to go from here.
My cards pass DigiTest
HD Core
HD Accel
HD Process
Old 03-19-2023, 10:09 AM
Buy a used 192 and keep the old one for parts?
Old 03-19-2023, 10:19 AM
Ok, I got somewhere.
I removed the Process and Accel cards and pro tools booted up!
So I guess I have a bad card that DigiTest isn’t finding.
Weird!
Old 03-19-2023, 10:47 AM
JFreak's Avatar
... or bad ribbon connection
Janne
Alright, this is what I got:
Core card by itself, session loads, interface is detected, output from i/o is working.
Adding ANY card to the core, using a different flex cable each time, the error occurs.
So could this be a buggered core card?
Old 03-19-2023, 03:31 PM
Ok, it keeps getting weirder!
So now if I put in the core and the Accel cards in, and plug the interface into the Accel card, Pro Tools loads!
