Old 01-17-2018, 08:49 AM
AntoninL AntoninL is offline
Default [Help needed] Using an Artist Mix & Mackie Control for FOH setup with a Fireface 802
Hi everyone,
I'm currently trying to see if it's possible to have a small live FOH setup with my RME Fireface 802, my Macbook and my Avid Artist Mix, using RME's TotalMix as a console, with its EQ and Dynamics, and with all the process done in the soundcard.
I've started before a similar post on RME's forum, here's the link :
https://www.forum.rme-audio.de/viewt...127624#p127624
For the moment, everything looks good, except that I can't find the button(s) I have to push on my Artist Mix to have the Mackie Control command "ARROW UP" or "ARROW DOWN" done, which would be very useful in RME's TotalMix FX...
Anyone knows how to achieve these commands ?
If not, is there another possibility ?
Something like a Mackie Control MIDI converter ?
I'm a bit lost...
Any help would be appreciated !
Thanks
Old 01-17-2018, 08:09 PM
Default Re: [Help needed] Using an Artist Mix & Mackie Control for FOH setup with a Fireface
Just my 2 cents....I'd be more interested in working within a PT session. Why? I get tighter integration with the Artist Mix and I would have access to lots of plugins that would work without latency(enough to bug anyone). Since you never actually roll transport, it should not be an issue staying at a small buffer(64?) Just tossing the idea out. I have not actually done this, but I have used an M-Audio Fast Track Pro into PT M-Powered and used it for reverbs and delay in a live setting(venue had an analog console and 1 crappy effect unit)
Old 01-22-2018, 09:03 AM
Thanks for your answer.
I have considered using PT as mixer, but as my laptop is an old Macbook Pro, I was looking for something more trustful...
I found a way to achieve what I was looking for, using MIDIPipe free-software.
On the link above to the RME Forum's topic, I tried to explain how I did.
I hope it could help someone :)
Artist Control initial setup challenge WilliebSR Artist Series 8 10-30-2014 08:23 AM
Talkback setup w/Artist Control and Apogee Ensemble dylannau Artist Series 8 10-02-2012 12:19 AM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
fireface 800 digi 002 setup raycan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-04-2008 09:28 PM
Digi 003/rme fireface 800/mackie onyx 800r johnnyz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-19-2007 10:40 AM
