Old 03-25-2014, 07:34 AM
Talisker Talisker is offline
Default Waves license not found after Waves update
After downloading a waves demo and therefore updating to waves 9.0, my old licenses are no longer found. PT asks for the 8.0 plugin folder on startup, even if I direct it there, it is not being recognized. Do I need PT 11 to use waves 9.0 ?
thanx for any help. All infos about my system are in the signature
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
Old 03-25-2014, 07:43 AM
nst7 nst7 is offline
Default Re: Waves license not found after Waves update
PT10 works fine with Waves 9. You must have inadvertantly done something when downloading the demo.
The Waves installers include an uninstaller, I would use that and uninstall everything Waves on your computer. Then re-download your existing version 8, or whatever it is.
Remember that with Waves installers, you can select only what you want to install.
If you have trouble with a demo, you can call them and get support as well.
Old 03-25-2014, 10:32 AM
The Weed's Avatar
The Weed The Weed is offline
Unlike Waves v8, Waves v9 (and up) does not use iLok for authorization. Use the Waves Licensing Center to put the (new) v9 license on your hard drive or a regular USB stick.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 03-25-2014, 11:05 AM
Ah, that at least seems to be the right approach to the problem. Looks like I would need to update my plugins to use them with Waves 9. So I think I will go back to 8 since right now I see no reason to invest the money for the update.
But thanx for the right idea.
Old 03-26-2014, 12:22 AM
JFreak's Avatar
JFreak JFreak is offline
I think you actually *should* upgrade, because as of now, Waves does not require surrendering your v8 iLok licenses and by simply re-WUP'ing you get another set of v9 licenses. Then you decide which version you use.
Janne
Old 03-26-2014, 09:14 AM
But the bottom line is that you shouldn't need to update all your plugins, just to try a current v.9 demo. I'm 99% sure that it's not needed.
Again, give them a call and they will help you through this.
Waves license (TDM-> SoundGrid) sjtae RTAS & TDM Plug-ins 16 08-29-2013 06:16 PM
WTB: Waves 5.0 License _Nexo_ Buy & Sell 0 08-06-2012 12:40 PM
Not enough space on Waves only ilok to download Waves update 7 crizdee Pro Tools TDM Systems (Mac) 38 11-09-2009 05:19 PM
waves platinum plug-ins nowhere to be found villagesound Pro Tools TDM Systems (Mac) 1 12-12-2007 09:58 AM
WAVES Protools7 update and Waves tech support x9blade 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 11-11-2005 06:24 PM
