Crash on exit whenever VEP is loaded
PT11.01HD has given me a consistent crash whenever I load an instance of Vienna Ensemble Pro latest aax2 download and then exit.
The crash reports a bex64 event. I've tried 2 diferent soundcards on the same pc. Is there anyone here that has VEP and PT11.01 running without crashes on exit? My setup: VEP 5 aax 64bit latest version, PT11.01HD fresh install after uninstall of 10.3.6 and reg clean, uninstall of all drivers etc i7 3930k/32GB GSkill/2011 chipset Asrock x79 extreme6 (not OC'd, all C states off, no HT, no turbo or speedstep or VT) Windows 8 pro 64bit, standard DAW tweaks, recently updated during tests. Soundcards tested: 1) Scope5.1 system on PCI extension chassis 2)RME Fireface Cheers |
Re: Crash on exit whenever VEP is loaded
bump..
Is anyone running VEP with 11.01HD without crashes on exit? 1) If so are they both latest versions? 2) Is your network set to a static ip? 3) Have you tried low buffer settings like 64 or 128 samples? [can the moderator please move this to the HD forum. I just didnt see anything related to v11 there] Last edited by bcslaam; 08-12-2013 at 11:46 PM. |
Im getting this in Pro Tools 11.0.1 Native on Mountain Lion 10.8.4... its random but often
Yes with static IP Loads fine and works fine until you try and unload VE Pro then it hangs and have to force quit Works fine in Cubase 7 and Logic 10
Pro Tools Ultimate 2023.6 Logic Pro 10.7.8 macOS Ventura 13.3 MacBook Pro (16-inch, 2021) Apple M1 Max Memory 64 GB PreSonus Quantum 26x32 Thunderbolt |
Oh yeah... ENDLESS crashes
over and over PT 11.1.2 Wondows 7 64 24 GB Ram Now it's crashing not only when PT is open, but also when it's closing too... (if I'm lucky enough to make it through a session long enough to close manually) But, to be fair, it was also crashing a lot before I loaded the new Vienna Ensemble in... seems to me that PT 11 was nowhere near ready for prime time Just restarted and got this Assertion in "..\ ..\ Sys\ Win32\ Sys_FileLocWin32.cpp", line 511. Fun! |
10.2 Crash on Exit?? Windows 7 | louieshowers | Windows | 11 | 11-23-2013 05:12 PM |
PT 9.0.6 Exit Crash on Win7 64 | DonM | Windows | 3 | 01-24-2012 06:14 AM |
Reaper crash on exit | S.TaylorRCC | Pro Tools 10 | 10 | 01-23-2012 10:16 AM |
protools 7.4 Crash and exit | abrigueiro | Pro Tools TDM Systems (Win) | 0 | 11-28-2007 04:13 PM |
crash on exit or save | kresho | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-02-2005 08:58 AM |
