Old 08-09-2013, 12:49 AM
bassmagnetic bassmagnetic is offline
Default Cannot create surround 5.1 output / bus
I've check through the forum and can't find the answer to my problem....
I am trying to create a surround 5.1 output / bus in I/O settings but Pro Tools is only giving me the option of creating a mono or stereo bus. The 1-8 outputs of my RME soundcard are shown
having looked through the forum to find other people with similar problems, I found issues reported related to 'surround mixer.dpm:
I have checked to make sure that the following file is present, and it is -
c:\program files (x86)\common files\digidesign\DAE\plug-ins\surround mixer.dpm
It is the same problem with both Protools 10.3.6 and 11...
Its a windows machine running Windows 7, RME Fireface 400 soundcard with latest driver v.3.077
Old 08-09-2013, 12:59 AM
Default Re: Cannot create surround 5.1 output / bus
Do you have Pro Tools HD (which supports surround) or just Pro Tools standard (which does not support surround sound)?
CPTK with Pro Tools 10 would also get you this. CPTK has been done away with in Pro Tools 11.
Old 08-09-2013, 01:25 AM
doh....
Yes I only have Protools (newly acquired!).... I didn't realise I can't work in surround with this version....
If I have multi-polyphonic bwav files is the only way of working to have them be split into mono's on import? I can't create tracks with more tracks than stereo?
thanks for your help
Old 08-09-2013, 01:27 AM
Protools standard that is......
Old 08-09-2013, 07:17 AM
Yep, without HD or CPTK2, you don't get surround. Of course, you can "create" the paths by feeding AUX sends to your surround outputs. Its a little "kludgy" but it can work.
Old 01-28-2018, 09:04 PM
sign3912 sign3912 is offline
I recommend that you can make 5.1 Mix template (Session create). Then, you can see 5.1 bus in I/O setup.
When you don't need any bus, you can rename.
And you can also make sub-path, which is LCR, Stereo, 5.1 etc..This is used to make 5.1 upmixing using bus in the situation in which you don't have 6output. (Only have 2output).
PT 9HD cant create valid 5.1 surround I/O binaryshrimp macOS 3 02-02-2015 01:56 AM
Can't Create Surround Paths MGalway Windows 2 06-02-2011 08:35 PM
output increases when I create new tracks nigel smith Pro Tools TDM Systems (Mac) 9 12-03-2009 01:59 PM
Output Surround mix Yasgur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-25-2007 11:42 AM
96 I/O as a surround output on OS X? janmuths Post - Surround - Video 2 06-21-2007 05:25 AM
