Mismatched Firmware
I am running 6.4 with all the updates. I just bought an 002 with an upgraded internal clock. Problem: the 002 is loaded with firmware version 1.21, but from what I can see the 6.4 has the firmware version 1.20. hence the system does not show signal. ProTools sees the 002r but no signal. Any ideas of how to fix this firmware issue? I can not find any firmware updates for my software.
B- |
Re: Mismatched Firmware
software doesn't have firmware......Hardware has firmware....it is inside of let's say a eprom chip inside your 002.....
Software has revision updates.....I wasn't onboard with any DAW when 6.4 was out....so i have no idea what is the latest version that Avid came out for 6.4.X......
Daniel HDX - PT12.5.1 - HD I/O 16x8x8 Win10-Pro (v1709)- 6 Core i7-6850k - ASUS X99 Deluxe ii D-Command Main Unit - 'Ole Blue http://www.sknoteaudio.com/ plugins rock and are affordable. Last edited by YYR123; 01-19-2012 at 07:22 AM. Reason: whoops......002 |
Correct, Software updates the Firmware residing in the Hardware
@bubba2112 I doubt it's a Firmware issue although of course, I could be wrong. There are other checks to make before concluding it's the firmware. It's most likely a second hand unit so the question has to be asked; did you check that the 002 was working properly when you bought it before you brought it home? You need to provide more info on your setup. Are you able to post some snapshots of an open session as well as your I/O setup in PT. The first thing to do is post a Sandra Report; Use SiSoftware's Sandra Lite application to generate a full system profile: www.sisoftware.co.uk Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions. After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
The 002r I have was running 8.0, I have 6.4, The prompt states that I need to download firware v1.20, I try too, but it doesn't find it. The 002 currently has a newer version v1.21, is my only course to get the newer 8.0 protools? This is what I am thinking.
The "download" is not from the internet, its actually already in the software. Next time you start Prop Tools and it ask if you want to "download" the firmware, click on okay and go for a walk(it can take 25-30 minutes). The firmware will "download" from the computer, to the 002.
Mismatched vertical zoom levels on tracks? | PPM6 | Pro Tools 9 | 1 | 03-25-2013 12:22 PM |
Firmware Updates lost fader pack. Firmware or personality? | Oakdale Post | ICON & C|24 | 0 | 03-23-2013 12:37 AM |
Mismatched sample rate causing pitch/sync issue in video | Searcher | Pro Tools TDM Systems (Mac) | 2 | 02-06-2009 12:19 AM |
keyboard instruments mismatched | pajordan | MIDI | 8 | 08-12-2002 08:50 PM |
Mismatched grouped regions | Kenshiro | Pro Tools TDM Systems (Mac) | 2 | 08-05-2000 12:51 AM |
