Old 03-10-2010, 04:35 AM
crizdee's Avatar
crizdee crizdee is offline
Default Keep Loosing all Waves presets from Waves tool bar!!
For some reason every time a load a session i lose all the Waves presets! all the one's saved from the waves tool bar (not the PT presets) i can load the presets file from the waves tool bar load menu and they'll be there again, but next session i load they're all gone again??
The presets folder is in the waves plugins folder applications/waves/plugins/plugin presets.
I haven't changed anything! this just started happening yesterday
latest waves . PT 8.0.1 Leopard 10.5.8
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-10-2010, 10:04 AM
Sean Russell Sean Russell is offline
Default Re: Keep Loosing all Waves presets from Waves tool bar!!
Try tightening them, then!
Sorry, couldn't resist. I can't help; I'm still running Waves 6x on all our systems here.
Have you tried re-installing the Waves or calling them? Do you still have your 8.0.3 install around to try to rule out PT? I remember you said you dropped 8.0.3 because of lack of Control24 modifier key support (which is weird cause I don't have that problem with 8.0.3/Waves v6), but was curious if you still had access to an 8.0.3 drive.
... but does it help the chorus?
Old 03-12-2010, 12:57 PM
crizdee's Avatar
Found the cause!
The waves plugin presets are now stored in user/shared/waves
There is an alias in the Waves plugins folder pointing towards this folder.
I have always kept a copy of my presets folder and then placed them back in the waves plugs folder after re-installing waves etc! which i what i did after updating Waves for the Kramer pie and HLS plugs.
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-12-2010, 02:02 PM
Craig F Craig F is offline
so you put them in the shared waves folder and all is good?
Thank you,
Craig
Old 03-12-2010, 02:59 PM
crizdee's Avatar
Yes, users/shared/waves plugin presets is where the presets folder is now stored! so thats where they need to be placed. if like me you have presets from years back, i have always kept them copied incase they get zapped during installs etc, like what just happened installing the latest waves 7 update.
Caught me out for a while!
Chris
Producer, Engineer,
www.ukmastering.com
Waves presets GS-DK Pro Tools TDM Systems (Mac) 0 01-19-2010 10:54 PM
Waves Presets ajastudios Pro Tools TDM Systems (Mac) 3 04-18-2009 05:15 AM
waves presets skyhigh5400 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-06-2004 12:33 AM
waves presets studiojimi Pro Tools TDM Systems (Mac) 0 04-17-2003 06:39 PM
waves presets studiojimi Pro Tools TDM Systems (Mac) 0 04-17-2003 05:43 PM
