Old 01-26-2010, 01:24 PM
john1192 john1192 is offline
Default Re: Logic Pro 9.1 with TDM Hardware
i think the OP is not trying to sync the two but use Logic with the PT hardware ...
sorry if i am stating the obvious ..
cheers
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-26-2010, 01:28 PM
crimsonnoise crimsonnoise is offline
I understand, but the sync settings still need to be right, as mentioned in my post.
PT 8.0.1cs1, HD Accel 2, Mac Pro 8 core 2.8GHz, Mac OS 10.5.8, Digi 192, ADAT Bridge 24, Logic 9.1 using DAE and Core Audio with RME Fireface 400
Old 01-26-2010, 01:39 PM
right on ... :)
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-26-2010, 01:56 PM
exactly..:)
Old 02-05-2023, 02:25 PM
zavid zavid is offline
Originally Posted by crimsonnoise View Post
John & Tornado.
A few questions, in order to get to the bottom of your problem: (I currently have Logic 9.1, PT8.01cs1, OS 10.5.8, Accel 2 working fine)
1. I assume you have tested that the hardware works as expected when using Pro Tools software instead of Logic?
2. Are you using only DAE or a combination with Core Audio or DTDM?
3. I have no experience with the Aurora but I assume it mimics a Digidesign 192? If yes, then you should set it to internal sync. You can do this from within Logic: preferences/audio/drivers/Digidesign hardware controls (or something like it) . Should you happen to use Core Audio at the same time, you can sync the Core Audio interface to the Aurora with word clock, and setting it to slave in that respective audio interface's software. No sync options should be enabled in Logic (just use internal).
Dom
Yes PT 8.0.3 is definitely not working with Logic. I think though the OP's versions should work but he may have some sync settings wrong.
So just to make it clear :
the last Pro Tools that allow Logic Pro/Studio V8 or V9 to use the Tdm-Dae engine
for process the plug ins with the HD cards Pci-x and Pcie
is the V 7 and its related updates ?
Or there is some exception of OSX, Pro Tools, and Mac Pro combination
that allow Logic V8-V9 to run with the HD cards Dsp processors ?
Logic Pro X and HD 192 Hardware DAS-Mike macOS 2 08-14-2014 09:44 AM
Logic Pro 7 with Mix system hardware? derF Pro Tools TDM Systems (Mac) 7 05-18-2006 09:32 AM
Logic with PT hardware gw sound Pro Tools TDM Systems (Mac) 23 09-15-2005 03:05 PM
Logic on HD Hardware K-Wolf Pro Tools TDM Systems (Mac) 4 12-30-2002 07:41 AM
Logic and PT hardware Lion Pro Tools TDM Systems (Mac) 1 12-15-1999 10:44 PM
