Old 05-18-2007, 11:51 AM
Joel Dougherty Joel Dougherty is offline
Default Pro Tools Adding .A(x) extensions to region names on import
I'm in the process of sorting through the dailies for a feature film.
Working in Pro Tools 7.2cs2, So channel suffixes are .A1, .A2, .A3, and so on.
When i import this audio into any other session, Pro Tools adds another .A1, .A2, etc. to the region name.
what gives? this is very annoying as it also separates the regions in my region bin.
Anyone found a solution?
Old 05-18-2007, 03:09 PM
NK NK is offline
Default Re: Pro Tools Adding .A(x) extensions to region names on imp
I have been dealing with this same exact "problem" I wish there were some preference settings for this, if I bring in a file with a specific name I do NOT want Protools modifying the name by adding a .A .1 or anything else.
Please let me know if you have a solution, other than going in and renaming each region and file after import.
Old 05-31-2007, 10:14 AM
Polaris Polaris is offline
Just ran across this myself today...what gives?
BTW, if you rename the file after it is brought into PT, it does indeed fix the name and nest the files properly BUT changes the modification date which if sure to make backups a pain.
Digi ????
Polaris
Old 05-31-2007, 02:27 PM
ewoklake ewoklake is offline
I emailed digi, this is what digi responded back with...
I do have a workaround you could try though that may speed up the renaming process.
Try the following steps
1. Create session,
2. Import audio to track
3. Highlight all of the audio.
4. Go to your edit drop down menu and choose the consolidate option (this will create new regions that are not part of the main region)
5. Highlight all of the audio regions again
6. In the Region bin drop down menu choose Auto-Rename
You can use this dialog box to rename your regions and number them however you would like. For example if you wanted your regions to be named audio.1 , audio.2, audio.3 etc you would fill in the dialog as follows
Starting Number: 1
Number of Places: 0
Suffix: leave blank
this will rename all of your regions to what ever format you would like.
Please Note: This will create twice the amount of regions you will actually need. You can use the Select All Used option and Remove or Delete to clean your session up.
Hope this helps
Digidesign Tech Support
Tech support stated that they have gotten a few complaints about this already, hopefully (wishful thinking) if enough of us write them they'll change it sooner rather then later....
Sound Editor
Dual 2.0 G5 RevB
2 gigs of ram
DVToolkit 2 PT 7.3
OS 10.4.8
Old 05-31-2007, 10:45 PM
Ray JB Ray JB is offline
Default Re: Pro Tools Adding .A(x) extensions to region names on import
Use Sibling collector from Maggot software.
Export the file list as text, point sibling collector at the text file and the folder of audio files and let it do it's work.
You will end up with all the sibling channels present in the session and then the channels will appear groups as you desire.
They only appear as a mass of regions if any of the other channels from the original multitrack file are missing from the session.
HTML code is On
region names too long in omf Newpostguy Post - Surround - Video 1 06-30-2010 02:24 PM
Missing Region Names thumky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-19-2009 08:29 PM
Region names corruption schiffdigital 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-22-2007 07:25 PM
adding versus importing into region bin srees Pro Tools TDM Systems (Mac) 0 09-06-2007 05:42 PM
printing the region names oreo1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-21-2006 08:48 AM
