Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 11-04-2020, 12:46 AM
DrewHarrison DrewHarrison is offline
Default Serious Routing Folder Bug!
I'm experiencing a rather serious routing folder bug that has now manifested itself separately on 3 different sessions. Here's how it begins...
1. After opening a session that previously had no issues, the audio in one or more routing stereo folders has an audible latency of about 10-20ms on one side (at 48kHz).
2. Making all inserts/plugins on the offending routing folder inactive will resolve the latency issue (if this is done during playback PT will crash).
3. Turning them on one by one will make the offending insert/plugin known, however, the insert slot and plugin (type and manufacture) vary from session to session, sometimes being more than one insert/plugin. The only 2 commonalities is that the offending plugin is always multi-mono and only manifests on Routing Folders, and not on Aux's or Audio Tracks.
Several times the bug started before sending the mix out for review to the client, and the client actually liked the sound with the latency added from the bug, causing me to waste lots of time trying to re-create the sound of the bug induced latency, and I've been unable to determine the exact amount of milliseconds latency because trying to re-enable the offending insert/plugin will often result in a crash.
Pro Tools 2022.12.0
Mac Pro 2019
OS X Big Sur
Old 11-04-2020, 07:44 AM
daeron80 daeron80 is offline
Default Re: Serious Routing Folder Bug!
Originally Posted by DrewHarrison View Post
the client actually liked the sound with the latency added from the bug, causing me to waste lots of time trying to re-create the sound of the bug induced latency.
Classic. Takes me back to the mid 90s when TDM systems used to occasionally become demon possessed and go into wild, grainy, undulating loops. One producer loved that so much and wanted me to make it do it on purpose. I learned to just keep an empty tape in the DAT machine to capture it for reuse.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 11-16-2020, 05:18 AM
ewanp ewanp is offline
I have just been getting this this morning in the first session I've worked on since the 2020.11 update. I'm getting the same timing offset delay - making the routing folder inactive and then active again will cure that folder, but the offset jumps to another folder, creating this hopeless game of whack-a-mole.
I can't pinpoint a cause here, and I have no multi-mono plugs on these routing folders. I have experienced this occasionally on 2020.9 - time will tell if it is more frequent or not on 2020.11.
The only fix I know is to save / close the session, quit Pro Tools and re-launch which seems to cure it. PITA, though....
________________
Pro Tools Ultimate 2020.11.0
OS X 10.14.6 (Mojave)
Mac Pro (Late 2013)
3 GHz 8-Core Intel Xeon E5
64 GB 1866 MHz DDR3 RAM
Lynx Hilo
McDSP APB-16
UAD-2 Satellite OCTO Core (Thunderbolt)
Old 11-16-2020, 07:51 AM
XJENSEN XJENSEN is offline
Yes, some delay compensation bugs exist on the folder tracks. E.g. check for any manual negative offsets, because these don't work correctly.
Old 11-16-2020, 08:07 AM
weezul weezul is offline
Experienced this myself last week. 2x Guitar tracks to a folder, identical plug ins. One side delayed and the other not. Restarting Pro Tools fixed it. macOS, 2020.5
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
Old 11-16-2020, 11:55 AM
Spooky things going on in Pro Tools, for sure.
Old 12-21-2020, 05:46 PM
[email protected] sleshnyc@gmail.com is offline
yes. what seems to happen though is that pro tools delays everything to compensate for the folder, but if you try to overdub anything, it's impossible. So i've learned no to create folders until i'm ready to mix.
Old 12-22-2020, 12:27 AM
Emi's Avatar
Emi Emi is offline
Does this bug happens with routing folder track only or both normal and routing folders?
Thanks
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 07-21-2021, 02:26 PM
taxontaxoff taxontaxoff is offline
Experienced the same issue yesterday in version 2021.6 (running at 48 kHz).
Mono audio track within a routing folder, panned straight up the center. No plugins on the audio track nor the routing folder.
When the track is assigned to 1-2, perfectly normal mono signal playing back.
When the track is assigned to Routing Folder -> 1-2, there's magically spread! And horribly impossible delay to play to!
Has this happened to anybody at a sample rate *besides* 48 k? If not, maybe I just run higher sample rates and keep my fingers crossed..
Routing folder+VCA mgoorevich Post - Surround - Video 12 09-30-2020 03:45 PM
Folder open / close not showing on control App for Auxes converted to Routing Folders pavoni Avid S1, S3, Dock and Control App 1 05-22-2020 08:20 AM
Another Folder Track bug: Soloing a Routing Folder doesn't solo routing bus XJENSEN Pro Tools 2020 7 04-24-2020 07:29 AM
Why can't I set my plugins root settings folder outside PT's default folder? RiF Pro Tools 9 4 09-26-2011 12:11 PM
Plug-Ins Alias folder points to wrong folder??? nod25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-26-2009 03:43 PM
