Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 11-01-2020, 01:49 PM
Ben Jenssen's Avatar
Default Stochas vst sequencer plugin in Patchworks?
This sequencer comes as a free vst/au plugin and I've tried to use it with Blue Cat Patchworks.
the main Stochas website.
It seems to work, except I can't find a way to route its midi output to a VI instrument plugin. I haven't used Patchworks much, so I'm hoping that there is something I'm missing.
Any ideas?
Unfortunately, it doesn't come in standalone version.
Old 11-01-2020, 02:17 PM
FunkzzaJ FunkzzaJ is offline
Default Re: Stochas vst sequencer plugin in Patchworks?
Yeah !
I wanted that one too. Better yet, if you have it, the new Falcon version 2.1 seems similar (even close to identical) as a new feature. Check UVI Falcon 2.1 presentation on youtube.
Old 11-01-2020, 05:03 PM
HA! I figured it out.
(Using a sequencer AU plugin to control a VI in PT)
You need to have two instrument tracks. One with the AU or VST midi seqencer residing in Blue Cat Patchworks, and the other with a AAX VI inserted. Then it's only a matter of routing the Patchworks output to the VI. They show up in drop-down menus in the Instrument part of the track channel strip.
This means I can use any au/vst sequencer, arpeggiator and such to control any VI. Great!
Old 11-01-2020, 06:13 PM
unkJE's Avatar
unkJE unkJE is offline
Thanks Ben for this - much apppreciated!
Originally Posted by Ben Jenssen View Post
...Unfortunately, it doesn't come in standalone version.
I ran the Stochas Windows installer twice to add both the VST3 and Standalone versions - (pics included)
I can also load Stochas in the Standalone version of BlueCat's PatchWork
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife!
Old 11-01-2020, 06:22 PM
OK, I must have missed that.
I'll not be needing the standalone, I think, with the plugin integrating, it seems, within PT for transport, input and all.
Old 11-01-2020, 06:32 PM
unkJE's Avatar
Here's some old PatchWork notes you may (or may not) have seen:
https://www.bluecataudio.com/Blog/ti...nth-or-effect/
Use PatchWork for Effect Plug-Ins, and PatchWork Synth for VIs
Quoting from:
https://www.bluecataudio.com/Blog/pr...in-io-routing/
“16 outputs for your instruments and the ability to configure audio I/O for each plug-in
• Route any of the outputs of an instrument to any aux output of the PatchWork plug-in.
• Apply effects to a subset of audio channels (for example to apply multi -mono effects on stereo or surround tracks, or apply different effects to different aux outputs fro an instrument).
• Create sends from a channel to another (re-routing a processed signal to another aux output for example, while the dry signal is kept on the current channels).
• Reorder audio channels.
• Apply effects to the side chain bus, or use any audio channel as a side chain.
Of course latency is compensated on unprocessed channels (if you apply for example a mono plug-in with latency only on the left channel, the right channel will be delayed accordingly).
Check out the new “Audio I/O” command in the plug-in menu”
Old 11-01-2020, 06:47 PM
Thanks, unkJE.
Yes, WOW, I'm only just getting to know this plugin, even if I've had it for years. It seems an extremely versitile tool.
But still, I must insist that my little breakthru tonight was that, a little breakthru.
How many here have used vst sequencer plugins to trigger your AAX VIs, raise your hands? I thought not.
Old 11-01-2020, 09:13 PM
unkJE's Avatar
...You need to have two instrument tracks. One with the AU or VST midi seqencer residing in Blue Cat Patchworks, and the other with a AAX VI inserted.
Or, with a VST3 VI inserted instead of an AAX VI, possibly hosted within a single instance of PatchWork Synth on just one Instrument Track?
(Yet to try this - could be totally wrong!)
I’ve triggered a drum VI with another VI, but never used a vst sequencer as a trigger.
This is no time for modesty, Ben, being this close to a major election – so I prefer to think of your “little breakthru” as something Bigger!
Without derailing ('tis vaguely related!) - here’s a few more gems from The Dark Side of The Cat, while we wait for others to celebrate your find:
Using Side Chain With Blue Cat’s PatchWork In Pro Tools
https://www.bluecataudio.com/Blog/ti...ools/#more-770
Using MIDI FX in Pro Tools
https://www.bluecataudio.com/Blog/ti...-in-pro-tools/
"you can use AAX plug-ins as MIDI Effects in Pro Tools"
How To Make A VST, Audio Unit or AAX Plug-In, In 20 Minutes!
https://www.bluecataudio.com/Blog/ti...-or-audiounit/
Old 11-02-2020, 03:20 AM
(Yet to try this - could be totally wrong!)/
I tried that, and several configurations - the only way to get polyphonic midi output from a Patchwork AU/VST to a AAX VI (or a VST) is by routing it with in/out settings in Instrument settings on the two instrument tracks. I think this is the clue. Both PIs inside a Patchwork instance, they didn't connect.
This is no time for modesty, Ben, being this close to a major election – so I prefer to think of your “little breakthru” as something Bigger!/
I see it as a door opening, new possibilities for experiments. And thanks to Brian Eno. One of my heroes. I found out about this "randomizing sequencer" Stochas thanks to a Eno youtube video.
That's great!
I have a lot to learn I think.
Thanks.
Old 11-10-2020, 02:44 AM
unkJE's Avatar
Realised I’d forgotten this great 2013 Thread by DonaldM – where Blue Cat Audio chimed in to help route Cthulhu chord/arp generator to any other VI in PT, using 2 instances of Blue Cat PatchWork Synth on one Instrument track and 2 MIDI tracks
https://duc.avid.com/showthread.php?t=348394
64 bit AAX Plugin Drum Sequencer MostOriginal AAX Plug-ins 3 07-28-2013 12:49 AM
Pattern Sequencer plugin? starburst MIDI 2 03-01-2010 11:29 AM
Looking for a sequencer/samples plugin rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-01-2005 08:17 AM
A good sequencer plugin for PT? voltech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-14-2003 08:43 AM
Transfering note data from a sequencer to the sequencer of the digi 001 sequencer? MichaelK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-05-2000 12:29 AM
