Old 10-24-2011, 04:53 PM
Drew6560 Drew6560 is offline
Default Cannot run drivers for 3 mini in win7
Just bought MBox 3 mini and I can't install it.
I am getting an error saying windows cannot access specified device. This only happens with the 3G drivers on the disc any other driver on the disc will open.
Also when I try to download the driver directly from Avid, the folder disappears from the download location as if it didn't download at all. Other downloads work just fine. I have done all the troubleshooting and system mods to get the best performance as suggested by the avid site. I have also tried running the drivers in compatibility mode mode in windows vista with the same results.
Thanks for your time
Old 10-27-2011, 11:09 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Cannot run drivers for 3 mini in win7
R U running PT9?
Daniel
Old 10-28-2011, 03:18 PM
no its 8.0.5
Old 10-29-2011, 08:49 PM
YYR123's Avatar
Default
Download it from another computer - that sounds real funny downloads diss appear - sure u don't have a virus issue - what does ur device manager look like ?
I am here: http://maps.google.com/maps?ll=29.993663,-97.866804
Daniel
Old 11-06-2011, 02:08 PM
I did attempt that and got the same results. I gave up and returned the mini3 and Hopefully I'll be able to find an affordable 003 or anything I can actually work with.
Thanks for your time and the response.
Old 11-06-2011, 09:51 PM
YYR123's Avatar
Default
Drew I just got my first HD setup - .so I have a 003r factory bundle with PT8 for sale - also I have not used this system to upgrade so u could upgrade to pt 9 for the reduced rate - let me know send me an email - [email protected]
I should charge Taptalk two pennies each time this message pops up !!!
Daniel
Win7 drivers for 002/003 bcwiz FireWire & USB Audio Interfaces (Win) 23 06-28-2013 04:47 AM
Has anyone gotten Win7 X64bit drivers to work on a Mbox2 USB? djgizmo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 12-10-2012 05:31 PM
Most up to date ASIO drivers for Win7? session_8 Pro Tools 9 1 11-08-2010 10:09 AM
Standalone ASIO drivers for Win7 x64 kenzo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-21-2009 07:57 AM
Help-confused drivers for win7 64 in the future? bokos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-13-2009 02:44 PM
