Old 04-07-2005, 09:36 PM
Agentemo1 Agentemo1 is offline
Default Protools Memory Leak???!!!
I am on of the few users who have had major problems with H/W buffer errors after 15 minutes of editing or doing anything..... i have found that when i watch task manager i have on gig of ram and protools starts off with 200,000K after 15 minutes it slowly rises to 940,000K then thats what crap hits the fan......somone please help or is it only a software fix..
Derek
Ok after much trouble shooting i have i think somewhat isolated the memory leak... I went back to pro tools version 5.3.3 on a bare system and no exrta plug ins.... memeroy was constant and up and down on usage... moved to versoin 6.1... same thing so were good up till i move to 6.7 where even with digi plug ins removed im still wathcing my memory sky rocket through the roof... ive talked to a couple other people who are programers and they say that its DEF not a hardware thing... and the only software i have is digi... it cant be windows i dont think cause 6.1 worked fine.... Digi please look into this... how do i get them to try and find out if this is them?
Old 04-07-2005, 10:42 PM
Default Re: Protools Memory Leak???!!!
Which plug-ins do you have installed.. remove all plug-ins (except the basics) and see if your problems persist.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-07-2005, 10:47 PM
Dogcode Dogcode is offline
Are you running dverb without a dither......just a guess....
PT 9
Control 24
003 Rack
Mac Pro 2.66 Quad
Adam A7
Waves Gold, VSeries
Pultec Bundle
URS, McDSP
Old 04-08-2005, 01:16 AM
xraydelta1 xraydelta1 is offline
did you play with the h/w buffer settings?
Old 04-08-2005, 11:52 AM
look at the top i updated my findings
Old 04-08-2005, 01:11 PM
mrufino1 mrufino1 is offline
What do you mean, D-Verb without dither? Are you supposed to run a dither plug after D-Verb? Does it cause cpu to hit the roof or memory to run out if you don't? I hadn't heard htis but it might explain some things if true...
Old 04-08-2005, 04:19 PM
Ducky Ducky is offline
This is a long known issue. To spare the repeat, simply put a 16bit dither BEFORE D-Verb in 24bit sessions and the CPU won;t run away with itself. Search the DUC if you need more info.
Old 04-08-2005, 05:39 PM
This is not a cpu problem im finding it in the memory
Memory Leak in Protools 10...? shameusf Pro Tools 10 26 09-16-2013 04:34 PM
Memory leak going 11.01>10.3.6 DetroitT Pro Tools 11 0 07-18-2013 03:42 AM
RAM leak still there (Protools running low on memory error)? Tim R. Pro Tools TDM Systems (Mac) 7 04-09-2011 12:41 PM
Memory Leak in 7.3? BlindDog Pro Tools M-Powered (Win) 2 01-15-2007 08:21 PM
Memory leak in PT7cs3? UnkleMik Pro Tools TDM Systems (Win) 1 02-03-2006 12:53 AM
