24 bit session to mp3
how can i take my 24bit session and bounce straight to mp3.. do i have to render my session as a 16bit wav. file first then to mp3...or can i bounce the 24bit session straight to mp3?
Re: 24 bit session to mp3
The bounce menu has a check box to create mp3.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Is the OP perhaps wondering what happens re dithering down to 16bit rather than truncating the 24bit to a 16bit .mp3?
I don‘t know if the OP wants to know if the signal will be truncated or dithered, but I...
Can someone explain, please?
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
If Pro Tools used (implemented) the Fraunhofer encoder correctly, there should be no truncation as the Fraunhofer encoder can work up to 32 bit float for input. In which case, no truncation and no need for dither. However, I'm seeing the bit depth dropping to 16 bit any time mp3 is selected (and greyed out so no option to change.) That may just be a Pro Tools display mistake. I'll have to check with a bit meter a resultant file to see if it is actually 16 bit when fed a full 24 bit file. If Pro Tools truncates to 16 bit before encoding, then dither should be applied (and dithering should be done to 16 bit). Update: Checked with a bit meter and it is not truncating down files when making mp3s so no dither is necessary. However, if you do the side-encoding ("Add mp3") and are also making a lower bit file, you should dither. For example: if you check Add mp3 and are making a bounce down from a 24 bit session to a 16 bit file, the mp3 is being created from the 16 bit file (which should have been dithered by the user with a dither plugin set on a master fader at 16 bit.)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 08-28-2018 at 12:45 AM. |
Thanks, that‘s good information. I will check with a bit meter myself.
ok but when i bounce to mp3 do i have to add dither on my master?
See BScouts post above-basically if the "Bit Depth" in the bounce dialog box is the same as the session then no dither needed.
Dither matters when you're throwing away 80-90% of the audio anyway?
Save session, close session, open session next day...clips have moved. | ptr22 | Pro Tools 12 | 8 | 02-18-2016 06:34 AM |
Pro Tools 9 crashes every time I open a new session or import session data | Ryan Butler | macOS | 14 | 03-23-2014 07:53 AM |
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 | doubtful guest | Pro Tools TDM Systems (Mac) | 1 | 02-06-2013 03:42 AM |
Vacuum patch gets shorter decay time at 96kHz session than 192kHz session | chrisdee | Virtual Instruments | 21 | 10-07-2011 10:02 AM |
End of Stream Reached - session broken - import session data does not work... | Sean Russell | Pro Tools TDM Systems (Mac) | 0 | 01-15-2010 04:56 PM |
