Where is my work
Okay so my work is nearly done, I have opened up the session to adjust the levels and its not showing any of the tracks or waveform's but the audio is playing so it is there. Have closed and reopened it multiple times.
Re: Where is my work
Hello and welcome to the forum.
Sorry to hear you are having issues with PT, but we are going to need a little more information about your system before we can begin to help. At a minimum, please read the Help Us Help You thread which contains general setup, optimization and troubleshooting tips. Also, the more detail we have about your issue, the better we can help. A quick guess would be that you don't have the Edit window showing. Make sure you have Window -> Edit checked in the menu bar on the top of the screen. |
Is the big gray "sand box " showing? if so are the edit and mix windows minimized/down at the bottom of the sand box?
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Ya, It sounds like your edit and mix windows are minimized. Just to be safe, back up the session until we can figure out the issue.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
My Pro Tools does not work! I can't get it to work with iLok | jarred89 | Licensing & Accounts | 19 | 11-08-2016 12:27 PM |
Next Victim - Artist surfaces do not work with PT11 but work fine with PT10 | jimmyjayp | Artist Series | 10 | 12-29-2014 03:38 PM |
Mackie Universal control Pro only work with protools11 dose not work 10.3.9 why??? | sayed mohammed | Windows | 6 | 11-11-2014 08:22 PM |
Audio Suite plugins that work in 10, do they work in 11? | David Sandwisch | Windows | 1 | 08-10-2013 08:14 PM |
How does Direct Connect work?? (Does it work well??) | tommydee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-18-2001 08:13 AM |
