Old 01-18-2015, 01:22 PM
marff3 marff3 is offline
Default Pro Tools Crashing On Session Open
Hi all,
I'm having an issue with Pro Tools crashing every time I open a particular session. This only happens with this one session and has not happened at all when I open any other session on my computer. Here is some background info on the session and what I've tried to remedy the situation.
Session Info:
- Worked on session on 1/6/15 with no issues. Backed up to external hard drive.
- Opened session on 1/12/15. Crashes shortly after opening.
- Session is rewired to Reason, multiple plugins, Izotope Ozone on Master track.
Steps taken to Fix Issues:
- Was able to open session and make Reason track inactive. Crashed.
- Opened session and removed Izotope Ozone. Crashed.
- Opened session and made all tracks inactive. Crashed.
- Made a copy of the session and opened. Crashed.
- Opened every backup file created by Pro Tools, many which had no plugins on at all.
- Opened backup from external drive. Crashed.
- Renamed session. Crashed.
- Checked all audio files for illegal characters. None found.
Computer info:
- Windows 7 Ultimate
- Intel i5-2400 CPU @ 3.10GHz
- 16GB RAM
- System Drive and Media Drive
- Saffire Pro 40 Interface
- Pro Tools 10
Error report from Pro Tools:
Problem signature:
Problem Event Name: BEX
Application Name: ProTools.exe
Application Version: 10.3.5.223
Application Timestamp: 516e4159
Fault Module Name: StackHash_e98d
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: 00000000
Exception Code: c0000005
Exception Data: 00000008
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: e98d
Additional Information 2: e98dfca8bcf81bc1740adb135579ad53
Additional Information 3: 6eab
Additional Information 4: 6eabdd9e0dc94904be3b39a1c0583635
Read our privacy statement online:
http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Ive tried everything I can think of. The strangest thing is that one day it opened fine, and the next time crashhhhhh. Other sessions open without any problems, even those with multiple plugins. Also Saffire Pro is set to highest buffer size for mixing (2048).
Any help or advice is greatly appreciated. I'm stumped!
- Matt
Old 01-29-2015, 10:56 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Pro Tools Crashing On Session Open
Originally Posted by marff3 View Post
Hi all,
- Matt
One thing you could try is to make a new session and import the session data from the corrupted session. I would import the tracks one at a time and see if there's one particular track causing the crash.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.12
Old 02-03-2015, 09:14 AM
digorysmallz digorysmallz is offline
Hey, I have the same problem here & seems to happen at least a few times a week while working. I usually just restart my computer or open up an autosaved session. I just upgraded from ProTools 8 & thought it would fix all the crashing but I guess that's just the nature of ProTools. I'm guessing there will be no upgrades to fix these in ProTools 11. Pretty sad it only went up to 11.3.
Old 02-04-2015, 02:04 PM
AntSantoMusic AntSantoMusic is offline
Have you tried holding shift while you double click the session file? If not, give that a shot and keep shift held down as it loads. This should disable all of your plugins. Activating plugins one by one may show you which plugins are giving you trouble. Let me know if that helps.
Old 05-25-2016, 01:20 PM
thierryhenry thierryhenry is offline
Brilliant thank you.
Cannot open any session without crashing. ReachMusicProductions Pro Tools 11 12 10-02-2013 12:59 PM
Pro Tools crashing every time I open a new session Ryan Butler macOS 25 10-12-2012 03:06 PM
Pro Tools 8 crashing when I try to open a session or start a new session AbstractHabitat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-25-2012 05:58 AM
PT crashing on session open Clockwork Studio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 08-13-2008 11:19 AM
