Old 07-06-2003, 04:36 PM
ZEUSS ZEUSS is offline
Default import plugins and settings
I am trying to import plugin settings and assignments from another session into a current session and it doesn't seem to work. I go to file and click import session data.Then select the session that I want to import the settings from.
Under session data to import I select Plugin assignments,plugin settings and automation. I then click ok. It doesnt import the settings. Is there something else I should be doing? I looked in the Ref Guide and couldnt find anything.
10.14.6 Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2019.12
Macbook Pro, 2019 (15,1) 32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2019.12
Old 07-06-2003, 07:45 PM
JLeigh2024 JLeigh2024 is offline
Default Re: import plugins and settings
Be sure to tell PT what track you're importing the plugin settings from and what track you're importing the plug in settings to.
Do not import I/O settings ChrisMac macOS 10 11-12-2012 02:11 PM
Copy/Paste plugins settings between different plugins? Zacsyd Pro Tools 10 9 05-02-2012 08:26 AM
Import mix settings Alex_C 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-21-2008 01:33 PM
Best way to import I/O settings? Lawson Pro Tools TDM Systems (Mac) 6 04-09-2005 07:31 PM
import plug in settings??? smlworld Pro Tools TDM Systems (Mac) 2 08-23-2001 01:22 AM
