Old 04-21-2008, 05:15 AM
Alex_C Alex_C is offline
Default Import mix settings
Hello
I am mixing some songs and have finished the first one.
Now I want to import my channel settings and plugins and
stuff into the next session and start there since I more
or less want the same sound in that song.
I know in HD that is real easy to do but it seems that in LE
that functionality is very limited.
I was just wondering if anyone has some good tips and tricks
on how to work around this limitation in LE.
An easy procedure or something.
I don't want to waste time assigning the same plugings and settings for all sessions
if there is an easier way.
Thanks in advance
Alex
Old 04-21-2008, 11:18 AM
macaholic macaholic is offline
Default Re: Import mix settings
It would take a little extra time, but you couldn't you save a session copy of your first mix, open that copy and delete all the audio files and wipe the automation, and then use THAT session as your "mix template"?? Then all you do is inport session data of the next song, and so on, and so on.
JC Richardson C.A.S.
Magick Lantern
Atlanta
Old 04-21-2008, 01:33 PM
Yeah that is true. That is a workable solution.
Thanks.
Do not import I/O settings ChrisMac macOS 10 11-12-2012 02:11 PM
is it possible to import settings from one project to another? TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-13-2010 10:43 PM
Import I/O settings problem? PTGuy Pro Tools TDM Systems (Mac) 2 04-03-2006 01:24 PM
Best way to import I/O settings? Lawson Pro Tools TDM Systems (Mac) 6 04-09-2005 07:31 PM
import plug in settings??? smlworld Pro Tools TDM Systems (Mac) 2 08-23-2001 01:22 AM
