Old 03-16-2008, 03:19 PM
Clockwork Studio Clockwork Studio is offline
Default PT crashing on session open
I am running PTLE 7.4, and just recently I am having problems with sessions crashing the software when I open a session. I have had some ongoing projects where I will start a session and get all the tracking done, and the next day when I'm doing the mix, the session will get to the point where it opens, and the software goes down. I had never had this problem up until a few weeks ago. Any help would be greatly appreciated.
Thanks in advance.
Old 03-16-2008, 08:37 PM
Default Re: PT crashing on session open
Also, this started happening after I made the power harness swap if that helps anyone diagnose.
Old 03-17-2008, 04:56 PM
Any help would be appreciated
Old 03-17-2008, 05:11 PM
DigiTechSupt's Avatar
You should start with the steps in the Win XP/ Pro Tools 6.x/7.x General Troubleshooting thread and post specific info on your system per the info on that thread if you're unable to resolve the problem.
You may want to look at the Help us help you thread as well.
Avid Audio Tech Support
Support FAQ
Old 03-18-2008, 01:11 AM
burnt burnt is offline
I have the same problem. When loading a session, the pro tools suddenly disappears. Pro tools version is 7.4cs3, computer is Lenovo T61, two gig of ram with lacie FW800 PCMCIA card. Some day it will open most sessions ok, but some sessions just won't start. Next day the same "problem-session" will open suddenly ok, but when I close it, the same thing happens again. I have done every step what troubleshooting thread suggests. One thing I do different, is that I hook my Lacie Firewire drive to digi002, so my chain is computer->digi002->FW drive. Tonight I'll try connecting the drive directly to the computer. Is it a problem to connect FW drive using FW800 port, because there's only one FW400 port in computer?
Old 03-18-2008, 10:26 AM
Teolin Teolin is offline
I was having similar problems and found that removing Massey demo plugs from the active plugin folder solved the problem.
Pro Tools 12.4
HDN, PCIe, Omni & Digi 192
ASUS Sabertooth, Intel i7 3820 3.6Ghz
32 GB 1600Mhz Corsair RAM
SSD 500GB Samsung
WIN 10 64bit
Old 07-23-2008, 05:31 PM
beyond beyond is offline
Default
Having same issue recently and I don't have the Massey plugins. Any other ideas as to why it's doing this?
Old 08-08-2008, 05:39 PM
mercbenz mercbenz is offline
Default
This happened to me when i moved my session and backup files. I still have sessions that wont open. Maybe a reinstall of pt would do the trick?
Old 08-08-2008, 07:13 PM
hookabruthaup hookabruthaup is offline
Default
Remove all plugins from DAE folder into unused, and then try and open your trouble sessions. if successful, start putting plugins back into your DAE and rebooting pro tools. I bet it's a bad plugin.
Old 08-09-2008, 05:50 AM
thebadboy thebadboy is offline
Default
Hey guys
I have a similar problem when I try to use the workspace browser - as soon as I click on the browser pro tools just disappears/crashes with no error or warning messages.
Been in touch with the tech support guys at digi but as of yet there is silence!
Why oh why
song will not open, could not complete the open session commandbecause...while transl SNAPPER Pro Tools 9 6 02-11-2017 12:32 PM
DAE Error 35 and crashing on "Open Session" NGL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 08-11-2014 09:46 AM
Cannot open any session without crashing. ReachMusicProductions Pro Tools 11 12 10-02-2013 12:59 PM
Pro Tools crashing every time I open a new session Ryan Butler macOS 25 10-12-2012 03:06 PM
Pro Tools 8 crashing when I try to open a session or start a new session AbstractHabitat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-25-2012 05:58 AM
