Old 04-05-2020, 07:58 PM
deadhorsestudio deadhorsestudio is offline
Default Avid HDX drivers for protools ultimate
I have an Avid HDX card. Installed it in my Magma Thunderbolt 3 chassis on my Mac mini running Catalina 10.15.
Protools Ultimate and System Prefs (sound) on the mini do not see my Avid IOs. Do I need a special driver for this?
Thanks! Jon
Jon Gold
Old 04-05-2020, 08:06 PM
Top Jimmy's Avatar
Default Re: Avid HDX drivers for protools ultimate
Did you install the HDX driver?
http://avid.force.com/pkb/articles/download/en379411
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.4.
Pro Tools HD Native 2020.3, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 04-06-2020, 12:20 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Was the TB3. Vs. TB2. Chassis issue ever resolved?
( outside of the new Avid brand )
(Help us Help You)<<<click here
APFS 90% 10% Audio on Both.
Pro Tools U-2020.5 macOS 10.14.6 APFS
Second boot-macOS 10.13.6 (Avid HDX-1 Omni)
(2k10MP 5,1 / 64-Gb)
(Sapphire RX-580 MVC-Edition-dual mini 6 pin. one spliced to add Avid mini 4 pin-hdx)
FW-CoreAudio (for poly-recording)
(SSL-HUI-MIDIoverIP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
new systems builds / upkeep / +
New builds:
12 core nMP HDX 1 Slot 5 stock HDX Mac mini 6pin to 4 pin HDX power like 5,1 mp's used)
16 core nMP rack-test station
28 just because machine
Old 04-06-2020, 12:35 PM
peterle peterle is offline
Digilink?
foley artist , soundeditor
Old 04-06-2020, 12:53 PM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by peterle View Post
Digilink?
That’s what I was guessing
Drivers and Digilink
Daniel
Old 04-06-2020, 03:23 PM
JFreak JFreak is online now
DigiLink i/o license is needed with PT 12.6 and later so if you have upgraded make sure you have that
Old 04-22-2020, 09:42 PM
SHayesSr SHayesSr is offline
Top Jimmy
My AVID HDX driver Icon shows up sometime a no show in Systems Preferences and Audio Midi Setup. When I oppen Pro Tools Ultimate using HDX as my Playback engine I get and Audio Midi Error message. Please see below.
I have the Avid HDX card housed in a Sonnet eGFX Breakaway Box w/TB3 connecting to an Antelope GoliathHD via two HDX ports. The GoliathHD is connected by TB2 using an adaptor to my iMac Pro (2017) running macOS High Sierra 10.13.2.
/Users/trinity1/Desktop/Avid HDX drive Icon.png
/Users/trinity1/Desktop/Error Message.png
I went to the link you provide but did not know which to choose, my interface being an Antelope GoliathHD.
SHayesSR
Old 04-23-2020, 08:43 PM
YYR123's Avatar
You need to also consider the Chassis might be bad, or the cables
The only way to get to the bottom of the situation is to troubleshoot with another system....like a MBP etcetera
Daniel
Old 04-23-2020, 10:45 PM
Top Jimmy's Avatar
Originally Posted by SHayesSr View Post
Top Jimmy
SHayesSR
Do you have a digilink license?
Are you following these instructions exactly?
eGFX Breakaway Box (GPU-350W-TB3Z) - Supports one HDX card. Avid Pro Tools HDX PCIe Card Power Adapter Cable and an Apple Thunderbolt 3 (USB-C) to Thunderbolt 2 Adapter required. Thunderbolt 3 Cable (40Gbps; 1-meter) recommended.
I have no doubt that the Goliath HD cannot run both via thunderbolt and the digilink at the same time. Is the thunderbolt connection interfering with the digilink connection while it’s connected?
James Cadwallader
Old 04-24-2020, 01:12 PM
Top Jimmy,
Yes I have a license for my Avid HDX card, iLok Manager License Manager.
Yes I connected the TB3 cable that came with the Breakaway Box to my iMac Pro TB3 port.
I did have both the connected. Now the TB3 is connected to my iMac Pro and I remove the cable from port 1 and 2 on the HDX card housed in the Breakaway Box from the Goliath.Rebooted and still the Avid HDX icon is a no show in System Preferences and Audio Midi Setup. Please see attached.
AVID HD Native thunderbolt + PT Ultimate last version aals Buy & Sell 21 03-30-2020 04:23 AM
Download of HD Ultimate Drivers prevents Mac Pro from rebooting Steve1 Pro Tools 2019 14 01-28-2020 07:44 AM
Avid Midi I/O drivers for Max OS Mojave and PT 2019.6 Ultimate pm mastering studio Pro Tools 2019 8 07-30-2019 10:58 AM
Avid Heat + Non Ultimate Pro Tools MikeP89 Pro Tools 2018 32 05-09-2019 06:43 PM
ProTools LE 8 on Windows 7- installation hangs at "Installing Avid Hardware Drivers"! jesster24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 12-20-2013 10:19 AM
