PT8 Original Installer Disk
Ok This seems to have been a documented problem. I have spent wayy too much time on the DUC tonight researching it.
I have just upgraded to WIN7/64....from XP clean install. The original disk will not finish loading and does nothing for a reallllly long time. I have not posted Sandra b/c the Drive works (i installed win with that DVD drive). and I used that disk to install on XP w.o issues. So my digi account doesn't show PT8 either......Wierd huh? I registered it when I loaded it up on XP......???? Searched way too many sites to try to find the issue and I can't. How do I get the PT LE 8.0.0 Complete Installer ???
Re: PT8 Original Installer Disk
Sorry about the trouble. We found your registration and will send you a DigiDelivery Link for the software.
Since you registered PT contact Avid, ask them to deposit the latest 'Full Installer' version into your account (I think it might be v8.03). Install with hardware interface turned off.
Use that to install PT then run 8.05 updater. http://avid.custkb.com/avid/app/self...p?DocId=393667 Win7 requires PT8.04 or higher to run. Alliteratively, if you can somehow get PT8.0 installed using current disk, just run the updater (do not uninstall PT first as updater's need full installation before they can run). With your current disk, have you tried right clicking PT exe file>Run as administrator? Also turn off any Anti Virus software.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
There you go.
This is interesting because all my PT versions show up in my account except PT8.
It shows from PT 5.1 to 7.4x and everything in between, but no PT8. It's also interesting that no registered hardware show as well, Digi or Avid.
URBAN MUSIC- (Hip Hop and R&B) |
Thanks JC - I did in fact get the email......I wish I would have posted that thread earlier....
Hey but its wierd b/c I still don't show that PT 8 LE is part of my registered products..... Anyway thanks I got what I needed....
Replacement PT LE 8 cd installer disk | Vmann | Eleven Rack | 4 | 12-06-2013 05:26 PM |
original disk allocation??? what this mean??? | pierreram | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-14-2005 08:44 AM |
Original disk allocation cannot be used???? | ryhiller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-18-2005 02:09 PM |
using "original disk alloccation" PLEASE HELP!!! | djbroc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-31-2005 10:41 AM |
Original disk allocation can't be used | tigergod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-13-2004 06:19 AM |
