Pro Tools 2020.5 won't launch on Mac mini
I have a 2018 Mac mini 3.2 GHz 6-core i7 with 64 GHz running on OS 10.15.5. I didd a "successful" install of pro tools 2020.5 but it will not launch. It always quits at this stage of the launch: Initializing midi engine. I've done a clean install of the OS, and protools and even wiped the hard drive. the Mac mini is brand new. Does anyone have a fix?
Re: Pro Tools 2020.5 won't launch on Mac mini
Hi, welcome to the community.
I have never seen this. Have you already contacted Avid Support?
Hi, thank you. Yes, I have been in contact with avid support and they have guided me through some steps over the last month and a half, but to no avail. I’m just getting impatient and hoping someone out there may have had the same experience and was able to find the remedy. Fingers crossed....
Sent from my iPhone using Tapatalk |
Btw. you have so low post count that anything you post via tapatalk goes to pre-approval for now. It will be lifted once you have enough posts.
Ok thanks
Have you tried holding “n” key during launch Then re select your playback engine?
Permissions admin?
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Just tried holding the n key while launching. I get the same results. Thanks for responding
Have you tried deleting the Audio MIDI Setup Prefs and also subtracting Aggregate from CoreAudio then relaunching?
Prefs would be com.apple.... Jeff Sent from my iPhone using Tapatalk Pro |
Hello,I tried trashing Audio midi prefs. That didn’t work. I don’t know how to subtract aggregate from CoreAudio.?
Thanks Sent from my iPhone using Tapatalk |
Also make sure your Mac does not have the user's home directory using iCloud... that's a total disaster waiting to happen. For the "clean install" you booted off the recovery partition and restored or did you do a clean download of an installer and build a boot/installer USB stick? I just want to make sure you really did a clean install and did not say accidentally do an OS update. Make sure the user is an admin account (should work without as well, but set it). Try creating a new Admin user and running from that account. Its extremely unlikely that there is such a generic bug in Pro Tools, and it's unlikely this is a hardware issue on your Mac... so it's much more likely something you are doing in setting up your system. |
Recommendations for a mini keyboard controller for Pro Tools 2020 | christopherc | Pro Tools 2020 | 5 | 08-15-2020 10:34 AM |
Pro Tools 2020.5/2020.3 Compatibility with Catalina 10.15.4? | derrickhou | macOS | 4 | 07-26-2020 07:46 AM |
PT 2020.3 crash on launch while scanning plugs | mj94122 | Pro Tools 2020 | 4 | 05-12-2020 06:03 AM |
Pro Tools (2020.3) on MacBook Air 2020 compatibility | pellekuipers | Pro Tools 2020 | 1 | 04-04-2020 08:01 AM |
Pro Tools 7.4 MBox 2 Mini won't launch in Windows 7 | pj77 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-25-2012 06:18 AM |
