Old 07-28-2018, 07:55 AM
Zergei72 Zergei72 is offline
Default DIGI001 / Presonus FIRESTUDIO project SYNCing
Is it possible to sync these devices, so I could use all analog ins on both of them ?
Old 07-28-2018, 07:17 PM
Default Re: DIGI001 / Presonus FIRESTUDIO project SYNCing
Yes, provided a few things are in place:
#1-the DIGI001 is fully functional and connected to the PCI card in the computer? I assume you have an older computer and are running Pro Tools LE6.4 or older?
#2-You have connected the firestudio to the computer and have assigned the 8 preamps to feed the lightpipe outputs(this requires some software from Presonus to make this routing)
#3-you set the sample rate of the firestudio to the same sample rate of your pro tools session(44.1 or 48K)
#4-with pro tools open, go to Setup>Hardware and set the clock source to ADAT(or Optical).
Old 07-29-2018, 03:28 PM
Ben Jenssen's Avatar
The problem is; The Firestudio Project doesn't have optical connections, as far as I can see. So that leaves you with SP/DIF and only two channels.
Old 07-29-2018, 06:29 PM
Aha....I had the firestudio(non-"project" version). So, new options:
#1-upgrade to Pro Tools 9 or newer and try the Firestudio as your interface(dump the 001 as it has no value these days)
#2-Keep the 001 with your antique computer and trade the firestudio for an 8-channel lightpipe preamp(Behringer ADA8200 being a great value at under $200).
Pro Tools 9 & Presonus FireStudio Project longiron07 Windows 9 03-12-2012 07:14 AM
Pro Tools 9 and Presonus FireStudio Project victorprotools9 Pro Tools 9 9 09-18-2011 08:56 AM
Pro Tools 9 I/O with Presonus Firestudio Project Mr. Dexter Ward Third Party Interfaces 3 09-10-2011 07:32 AM
Presonus Firestudio Project + Digi003 rack+ DanRock Windows 1 01-16-2011 11:39 AM
Digi 002 with presonus firestudio project? Joevr4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-04-2010 12:41 AM
