Old 05-21-2020, 02:58 PM
michaelhulse's Avatar
michaelhulse michaelhulse is offline
Default Re: EUCON 20.5.0 released
I have uninstalled a couple of things this evening. They worked fine. It's perplexing.
MP 6,1: Quad:64GB,256GB Flash,2-1TB SSD in TB Dock,Mac OS 10.12.2/3-27"&1-34" Mons/Artist Ctrl,Mix(x2),Trnsprt, Eu 3.5/Apollo Quad TB2/M905 Dig/LSR4326P & BX8A Mons/PT12.7/LPX10.2.4/S1v3/Advance49, S88 Komplete Kontrol 11 Ultimate/Radial 6pk : 1073LB, MonoGama, 512C, VHD Mic Pre,611DYN,611EQ/Variax 89F, PRS C22, /FAS AxeFX II XL+/DM10Kit/Win10 on i-7 Haswell PC with 16GB RAM/828mk3 FW/CW2016Platinum/Tobias&Tune Basses, Mesa M-Pulse 600, GK 1001RB-II Bass Gear/Neumann, CAD, AKG, Telefunken
Old 05-21-2020, 03:06 PM
Older installer 2020.1 does the exact same thing. Installers older than that won't even open.
Old 05-21-2020, 03:07 PM
By older I mean 18.3 and 2019.12
Old 05-21-2020, 03:35 PM
EddieJones's Avatar
I found this lik you could try https://support.microsoft.com/en-us/...led-or-removed
Old 05-21-2020, 03:36 PM
EddieJones's Avatar
Have you tried an uninstall from windows Apps and Features in the settings ?
  #16
Old 05-22-2020, 02:13 AM
Hi Eddie,
plugin/pan window follows track select keeps being a moving traget. Now it seems like the pan window ALWAYS opens when clicking into a track even when when you haven't gone into pan mode on the Artist Control.
The only way to prevent that from happening is set Eucon "open windows when editing" to off or plugins only.
When you have a send open and move to the next track the send closes and the pan window opens even when you still have the Mix set to AUX. (this is with close on exiting off btw.)
However when you have an EQ open that will follow the track selection fine without the PAN window constantly popping up.
It's seem like this behaviour changes on every Eucon release and the identical setting.
Is there a way to just have the pan window open when I actually press the PAN button or touch the rotary on the mix and only then?
Thanks!
Frank.
  #17
Old 05-22-2020, 11:45 AM
Thanks, Eddie. I will try those and get back with you.
  #18
Old 05-22-2020, 11:54 AM
Eddie, you're a genius. I have not tried using EuControl, yet. But the Microsoft Install/Uninstall tool worked like a charm uninstalling. It said it fixed a few problems, and to try my installation, again. I did, and it installed flawlessly.
I bookmarked that sucker!!!
Thanks, again!
  #19
Old 05-26-2020, 02:41 AM
I'm getting a very long lag when pressing solo/mute on the artist mix since the update. Sometimes it takes up to 4-5 seconds for the solo or mute to actually activate. It seems to be inconsistent. Sometimes it's quick as normal but very often it takes unusually long.
What's also new is that my only layout doesn't get recalled after booting everything up in the morning. It used to "survive" a power-cycle in the previous version. Now I have to manually recall it from the Eucon App.
Also sometimes when I hit solo the layout is lost and goes into all auto assigned mode which happens very often and is quite an annoyance because I lose all my master fader on my Artist and I have to open the Eucon App to recall it manually.
F.
  #20
Old 05-26-2020, 04:43 AM
Freechess Freechess is offline
My Artist Mix (since EUCON 20.5.0.149) doesn't display the fader values of the touched faders anymore. It works again after randomly changing the Fadervalue-settings in "Miscellaneous", but after about a minute - again - the display doesn't react anymore.
EUCON 20.1.0 Released EddieJones Avid S1, S3, Dock and Control App 44 05-08-2020 11:59 PM
EUCON 20.1.0 Released EddieJones Avid S4/S6 11 03-09-2020 11:35 AM
EUCON 20.1.0 Released EddieJones Artist Series 2 03-03-2020 07:31 AM
EuCon suddenly broken - Eucon client can not access the bonjour service noiseboyuk Artist Series 0 04-12-2016 12:34 PM
