Old 04-08-2011, 10:54 AM
SolutionRoom SolutionRoom is offline
Default Pro Tools 9 Hardware Insert Delay Compensation with Lynx AES16e and Aurora 16
If anyone is interested, I was able able to run the tests and determine the round trip latency of Pro Tools 9 with the AES16e card and an Aurora 16. Here are my results.
If anyone might have anything to add, or refute, please let me know. I am certainly no scientist or math major. Otherwise, I will be plugging these numbers into the Hardware Insert Delay settings of the IO section to compensate appropriately for the delay incurred by the Lynx hardware when using external Hardware Effects (Hardware Inserts).
At 44.1k - 29 Samples - 0.66ms
At 48k - 29 Samples - 0.60ms
At 88.2k - 22 Samples - 0.25ms
At 96k - 22 Samples - 0.23ms
* These figures were computed by following the instructions in the Pro Tools User Guide (Page 963)
* The number of Samples divided by the Sample Rate = Milliseconds
Example: At 44.1k - 29 Samples divided by 44.1 = .66ms
Switching from HD Native to Lynx AES16e ? jacko macOS 0 01-10-2013 02:22 PM
lynx aes16e and aurora? Alexmc1988 macOS 0 04-27-2011 08:22 AM
can't get lynx aes16e to work with more than two converters on pro tools 9 brett_ooo macOS 1 02-23-2011 04:27 PM
PT9 / LYNX AES16e - Loud noise when changing outputs geelo Pro Tools 9 0 01-16-2011 12:05 PM
Hardware insert delay question - Aurora freedomof81 Pro Tools TDM Systems (Mac) 4 01-26-2010 11:10 PM
