Old 08-07-2019, 06:17 AM
docric docric is offline
Default Dock: "OK/Cancel" buttons not working??
Probably user error, BUT ...
... after upgrading to Eucon 19.7.0, when a pop-up screen displays from PT with an "OK" or "Cancel" choice, I can no longer open/close those windows by selecting the "OK" or "Cancel" button on the Dock??
I've gone into both Eucon Settings & PT prefs and tried various selections of the new options & for the life of me, can't get this working as it did previously ??? ... I've gotta' be missing something simple... any help much appreciated !
... and the Dock Right Edit commands seem ?? to be correct (Global>Enter for "OK" & Global>Escape for "Cancel")...
-C' ya'
Rick
MacPro 7,1; 16 core OSX 13.5.2
PT 2023.9; Eucon 2023.6
Dock/S1/2x iPad
Old 08-07-2019, 04:40 PM
mattrixx mattrixx is offline
Default Re: Dock: "OK/Cancel" buttons not working??
Given that some of these "ok" response options require ProTools to be the front most, or attention app, for them to work... can you check to see if this is the case, or is it for all of them in your case?
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 08-08-2019, 05:18 AM
Thanks for the input, Matt.
Unfortunately in my case, having Pro Tools, or even a specific window in Pro Tools attentioned (or not) doesn’t seem to affect it??? Bizarre, huh?
I’m beginning to suspect macOS but just can’t figure this one out...
-C' ya'
Rick
Dock/S1/2x iPad
Old 01-08-2020, 09:42 PM
MediaBrain MediaBrain is offline
I'm having the same issue. I'm pretty sure it's a bug and has something to do with MacOS breaking something in Eucon although that's just a hunch.
Here's a hack that fixes things though I'm hoping Avid will resolve this in a future Eucon update. See attached screenshot.
For whatever soft key or surface you want assigned as OK or Cancel, add a KEY command for Keypad Enter or Keypad ESC. The Eucon globals for these don't appear to be working for whatever reason. This will get you going until the next bug fix.
File Type: jpg Screen Shot 2020-01-08 at 11.34.15 PM.jpg (48.6 KB, 0 views)
Old 01-11-2020, 05:29 AM
Niiiice MB !
Fortunately, this issue resolved itself when I updated to the next Eucon/PT version.
-C' ya'
Rick
Dock/S1/2x iPad
Old 07-20-2022, 12:51 AM
WildHoney WildHoney is offline
I'm seeing this again here, but adding the ENTER keystroke does the trick as a workaround. good tip, thanks!
Feature Request: swap "mute" and "sel" buttons made Avid S1, S3, Dock and Control App 0 06-19-2019 06:26 AM
PSA: Make sure to cancel your Pro Tools Expert "subscription" billcarroll General Discussion 40 06-15-2018 12:41 AM
SOLVED - Dock Left Edit "Shift" greyed out simonchase Avid S1, S3, Dock and Control App 5 03-14-2017 11:50 AM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
OT - Shortcut for "Cancel"? Stig Eliassen Pro Tools TDM Systems (Mac) 6 07-05-2010 09:17 AM
