Old 12-10-2001, 10:31 PM
dinodigi dinodigi is offline
Default Recording Organ/Vox in church
Any tips from those with experience tracking organ (lg. pipe organ) and vocals in a church would be appreciated (not "live", i.e. we could track Vox later) [img]images/icons/confused.gif[/img]
Old 12-12-2001, 03:45 AM
David Wright David Wright is offline
Default Re: Recording Organ/Vox in church
I frequently record pipe organs for CD, both as solo instrument and accompaniment to choir or solo voice. My aim is always to present the (presumably church) acoustic as an integral part of the sound - indeed it's difficult to avoid doing so as recording pipe organs close up is not usually very effective as all sorts of action noise show up, also the sheer size of the instrument means a good balance is only heard at some distance.
A matched pair of good omnis spaced well apart often works well, giving a warm, wide-range sound. In UK churches (where I work) a coincident pair of hypercardioids often gives better results due to the more spacious acoustics we tend to have over here.
Be prepared to experiment - organs vary so much it's impossible to be very specific.
Old 12-12-2001, 08:47 AM
Thanks for the response David!
Any particular kind of coincident hypercardioids that you are using? (about to invest in some more gear, and looks like I will be doing a lot more of these church/organ/choir "sessions"
cheers
Old 12-12-2001, 09:38 AM
Doug Ring Doug Ring is offline
If it's a trained classical singer they'll have no difficulty singing against an organ. Indeed, the piece will probably be written to allow the voice to be heard, unless this is a new work or not in the classical repertoire. I'd position the singer as far away from the organ as they feel comfortable with, and spot mike them from about 4 feet away. Then as David suggests, I'd use a coincident pair of cardioids on the organ. Find out where the pipes are - the visible ones on the case are often dummies. Put your stereo pair up as high as you can get them - consider slinging them if you don't have a high stand - and put them at the apex of an equilateral triangle formed by the width of the pipe set and your mics as a starting point. If that's too close, move out, or add a second pair for ambience.
You might consider the Oktava MK12s for this job. Very good value and strong performers. Or, since the bass pedals go really low, 414s?
Old 12-13-2001, 02:09 PM
I use the Calrec Soundfield mic which allows me to simulate any combination of polar pattern and capsule angle, or an M-S pair consisting of Sennheiser MKH40 cardioid and MKH30 figure-8 which emulates a pair of hypercardioids.
AKG414s would also do fine.
I agree with recording the vocal with the organ rather than overdubbing later - much better for rapport between performers. I usually use an omni for spotting a soloist - it gives a better blend with the organ.
Old 12-13-2001, 03:24 PM
Aah, the Soundfield! A very fine mic. I've used the cheap version - the ST 250, but the control unit doesn't allow all the tricks that the Soundfield's will.
David, do you output four tracks to Pro Tools? And what converters do you use?
BTW, have you ever recorded the new organ in St Giles Cathedral, Edinburgh (my home town)?
A fine instrument with a mechanical action and a changing room for the organist INSIDE the organ! Seriously! You go in a little door and pass underneath all the control rods from the keyboard. It's like being inside a living thing.
Recording an out of tune organ uQbar Pro Tools 9 11 11-16-2011 05:38 PM
recording an organ callmesonny19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-06-2007 08:07 PM
Recording Church Bells superpenguin79 General Discussion 28 01-25-2006 04:54 PM
Recording Choir & Organ SHIRK Pro Tools TDM Systems (Mac) 7 06-18-2003 08:31 AM
Tracking Organ/Vox in church dinodigi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-12-2001 12:00 AM
