6085 and 6088 Errors - Just Started - Sandra Report Included
I just started getting these errors and I can't even get through a song. Seems to happen during playback and not as often during recording.
I've tried changing the buffer and keeps happening. The only thing different is now I'm using a Kensingyon Expert Mouse and an external keybord on my laptop. It's a small session. 5 audio tracks with an aux track for reverb and the other tracks send to this track. I have followed all of the recommendation's in trouble shooting. SiSoftware Sandra Processor Model : Mobile AMD Athlon(tm) 64 Processor 3400+ Speed : 2.21GHz Model Number : 3400 (estimated) Performance Rating : PR3969 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile Internal Data Cache : 64kB Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache : 1MB ECC Synchronous, Write-Back, 16-way set, 64 byte line size Mainboard Bus(es) : ISA AGP PCI IMB PCMCIA CardBus USB FireWire/1394 i2c/SMBus MP Support : 1 Processor(s) MP APIC : Yes System BIOS : Phoenix 0F08.P00 System : eMachine Shadow-K8 Mainboard : eMachine Shadow-K8 Total Memory : 1.2GB DDR-SDRAM Chipset 1 Model : VIA Technologies Inc Apollo K8T800 CPU to PCI Bridge Front Side Bus Speed : 2x 800MHz (1600MHz data rate) Chipset 2 Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed : 2x 800MHz (1600MHz data rate) Total Memory : 1.3GB DDR-SDRAM Memory Bus Speed : 2x 157MHz (314MHz data rate) Video System Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Plug and Play Monitor Adapter : ATI MOBILITY RADEON 9600/9700 Series Physical Storage Devices Hard Disk : IC25N080ATMR04-0 (75GB) Hard Disk : Disk drive Hard Disk : Maxtor OneTouch USB Device CD-ROM/DVD : HL-DT-ST DVD-RW GWA-4040N (CD 24X Rd, 16X Wr) (DVD 3X Rd, 2X Wr) Logical Storage Devices Hard Disk (C:) : 75GB (58GB, 78% Free Space) (NTFS) Protools (F:) : 190GB (151GB, 80% Free Space) (NTFS) CD-ROM/DVD (D:) : N/A Reason (G:) : 190GB (140GB, 74% Free Space) (NTFS) Peripherals Serial/Parallel Port(s) : 1 COM / 0 LPT USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : Generic USB Hub USB Controller/Hub : USB Composite Device USB Controller/Hub : USB Printing Support USB Controller/Hub : USB Mass Storage Device FireWire/1394 Controller/Hub : VIA OHCI Compliant IEEE 1394 Host Controller PCMCIA/CardBus Controller : Generic CardBus Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Keyboard : Microsoft USB Digital Media Pro Keyboard (IntelliType Pro) Mouse : Kensington PS/2 Mouse Driver Mouse : Kensington HID Expert Mouse Human Interface : HID-compliant consumer control device Human Interface : HID-compliant device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Human Interface : Kensington USB Expert Mouse MultiMedia Device(s) Device : Realtek AC'97 Audio for VIA (R) Audio Controller Communication Device(s) Device : Conexant SoftK56 Data Fax Modem Printers and Faxes Model : QuickBooks PDF Converter Model : PDFCreator Model : Microsoft Office Document Image Writer Model : EPSON Stylus Photo 820 Series Model : Brother HL-2040 series Power Management AC Line Status : On-Line Battery No 1 : 100% Operating System(s) Windows System : Microsoft Windows XP/2002 Home 5.01.2600 (Service Pack 2) Network Services Network Drivers Enabled : No Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings. Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Macbook Pro 2.16Ghz, 4 GB RAM, OS X 10.6.8, 1-Maxtor 200G & 1-OWC 80G External Firewire Drive. - Pro Tools 9.0.3 |
Re: 6085 and 6088 Errors - Just Started - Sandra Report Included
The problem I see is that you only have one hard drive. Protools really is designed to use a physically separate drive for the audio. Using you system drive for Protools is not recommended and is most likely the cause of your troubles. Perhaps you didn'y have this before by chance. Chances are that it can't keep up with the demands of Protools anymore. USB drives are not recommended as they can not keep up the sustained data transfer rate. In the case of notebooks, an external Firewire drive (7200 RPM minimum) is required.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Actually I have 2 external hard drives. One is via firewire for Pro tools and the other is via USB2 for Reason. I'm not sure why it doesn't show on the report. I have everything running.
I tried a M6811 and couldn't get it to work. I worked on it for months and months and bought all sorts of cardbus adaptors, sent it back to emachines, harddrives, reinstalled everything, disabled everything.
I gave it to my wife to play games on. I bought a MacBook pro and I'm so happy. No errors. Wish I had a fix for you but there is something in the M6811 that = 6811's, 6088's etc. John |
I really can't afford to buy a new system right now. What did your MacBook Pro run you and what were the specs on it?
Are these suppose to be out performing the desktops now?
6085 and 6088 usually indicated a firewire bus communication error.
You say the only things that changed between when it was working and when it stopped was adding the new mouse and keyboard? Is the keyboard wired or wireless? Have you tried disconnecting them to see if the problems still occur? How many firewire ports does the computer have and how to do you have the 002 and firewire drive connected, exactly? |
I don't know how many verbs / tracks it will run but check on the Mac side, someone over there will know. DigiTech support is right, kinda. Can you go back to a previous configuration and will that work? I know that a few people were able to get the M6811's to run, I just never never could. That was what was so frustrating for me. (Search my past posts) I think there is something in the FW chipset that prevents them from working with PT. I blame Digi for that. PT should't be so damn fussy. John |
I then tested another session and the issue was not there. So this made me think there must be something unique to this session. I started by removing plug-ins. Still had issues. Next I checked see if maybe I had stored the session on my system drive and not the external drive. In doing so I discovered the session was on the external drive but some of the audio files were in a different folder (template session)than the actual session. So I moved the files to the current session and it resolved the main errors and everything is now working like it did before. Which is good. How can I prevent this when starting from a template? However, I do still get some -6085 errors, although nowhere near the amount I experienced when raising this issue. I changed the DAE buffer to Level 4 and that helps some. Quote:
I hope you may have some advice to improve the sittuation? It's not as bad as it was but I did have the error twice in 7 minutes and had to restart the recording of a session. Thanks.
So, does this still just happen in the one session, or other sessions as well?
It's very strange that moving audio files on the drive would change the frequency of errors. My first thought was fragmentation, but that shouldn't be the case given how much free space you have on all your drives. I wonder if these audio files may be corrupted somehow. You could try doing a 'Save Session As' to a new location on the drive, making sure to choose the option to copy all audio files, then close the current session and open the newly saved one to see if you still get the errors. |
I'll have to experiment with some other session's to see how it's acting. I know last night I was mixing the session and had the error again during the mix and again during bounce to disk. I again changed the DAE buffer to level 4 and it allowed me to finish. I wouldn't think they wouild be corrupt only because the session was a day or 2 old. Not that this means they couldn't be. I'll try your suggestion and test some other sessions and reply back.
3 critical errors I'm regularly receiving (Sandra Report Included) | TheJamsh | Windows | 2 | 12-11-2011 10:12 AM |
Pt9.0.5 Help Please (Sandra Report Included) | msuk | Windows | 2 | 09-25-2011 08:48 AM |
Three problems since 8.0.4 - Sandra report included. | David Sabine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-22-2010 10:44 AM |
(-6088) and other errors (Sandra report enclosed) | powerjoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 02-09-2010 07:53 PM |
9073 errors - sandra report included. | djgizmo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-03-2010 03:26 PM |
