Old 08-20-2017, 07:04 PM
jalani_music jalani_music is offline
Default Problem with 003 Rack Aux In Button
The 'Aux In' button/light on my 003 Rack keeps switching on and off by itself. When on (lit), I can't switch it off, and vice versa. I'm using PT LE 8.0.5, OS X 10.6.8 Snow Leopard. I recently unplugged my gear for a few weeks while I remodeled my studio. When I connected it back up, the problem started. I've done the firmware update (twice), checked connections, changed inputs, etc. and nothing's helped. I've had the unit for about ten years...never had a problem. Couldn't find anything about this problem in the forums, or anywhere else. Any advice?
Old 03-31-2020, 02:27 PM
aveed aveed is offline
Default Re: Problem with 003 Rack Aux In Button
I'm currently having a similar issue with the Digi 003 Factory console. When I turn on the 003 with nothing else connected expect the power into the wall, the aux-in button will click on and off intermittently having not even touched anything.
I spoke with an electronics repair person over the phone and explained the symptoms and he said that it sounded like the aux-in switch was failing and if so, would need to be replaced.
To try and diagnose further, I pressed the Utility button and selected Test/Buttons. The aux-in button was being intermittently triggered without pressing anything and the test display blinked "Aux In - Region 015 - Switch 013".
Did you ever resolve the issue you were having and if so, how?
Has anyone else experienced similar issues? Fixes/suggestions?
Thank you!
Last edited by aveed; 03-31-2020 at 02:38 PM. Reason: Clarify the issue I was having.
Old 04-01-2020, 03:11 PM
some things to consider:
#1-you dredged up a 3-year old thread(not sure if that helps or hurts)
#2-the 003 is past its expiration date and is probably not worth the cost of repair(unless you can get the part and replace it yourself)
#3-is it stuck ON or stuck OFF? If its stuck OFF, what are you wishing it would do?(Maybe there's other solutions besides repairing or replacing it)
Button issues on 11 Rack. JCcares Eleven Rack 4 12-07-2012 06:48 PM
digi 003 rack mono button problem blueside 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-25-2009 04:52 AM
Recessed Power Button on 002 Rack digijohn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-07-2007 04:30 PM
002 Rack Mute Button Frozen Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-03-2007 05:33 AM
002 Rack- Phantom power button on back!??? JPS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-02-2003 12:06 AM
