Inexpensive Midi Controller Anyone?
My Axiom 49 keeps dropping its connections in PT 12...did that in the past but seems to have gotten worse.
SOOOOO.... I'm looking for an inexpensive Controller. Needs to RELIABLY WORK under Windows 7 Pro 64 Bit and PT 12. I DON'T NEED all the bells and whistles....say a 49 key to trigger Strike and the other AIR plugins. Under $200 would be perfect. :) I would appreciate any suggestions.
Patrick www.LightWingStudios.com Musical Instrument Protection Accessories...Made In America. Dell Precision T7910, Dual Processors (total 20 Cores), 128GB RAM, 4 @ 2TB SSDs, 1 @ 4TB HDs, Nvidia 2GB Dual Monitor Card, Dual LG 48" TVs used as Monitors, Arturia 88 Midi Controller, Black Lion USB Audio Interface, Mackie HR-828 Monitors, Katana Head, Fishman Triple Play, Win 10 Pro, PT 2023.3 Studio, only the Plugins I NEED, WAY TOO MANY Guitars...and an AMAZING wife! AxeShield HD, AmpShield HD, KeyShield HD, AxeSak, AxeGlove, AxeCap & PedalShield |
Re: Inexpensive Midi Controller Anyone?
Axiom Pro? I would recommend pawn shops as well, when you tell the guys to hook it up, and it doesn't make sound....you could be in for a BIG discount!!!
I'd prefer to stay away from M-Audio and Axiom series for the reasons I stated above but thanks for the post.)
So, maybe an odd question, but I seem to ask it a lot. Did you disable your USB power management so it doesn't shut off the USB port?
sw rec...Yes sir! Did all the recommended optimizations...
It IS weird tho. After I power on the Axiom it will be fine for a few minutes and then I can see the display on it start changing all by itself without doing anything on my past. If for example I am using STRIKE, it may be fine triggering different patterns for a time and the it goes out to lunch. No matter what key I press the SAME pattern is played. The Midi Out is wired to the Midi In of the Presonus AudioBox USB. Midi Over USB is turned OFF on the Axiom.
Patrick www.LightWingStudios.com Musical Instrument Protection Accessories...Made In America. Dell Precision T7910, Dual Processors (total 20 Cores), 128GB RAM, 4 @ 2TB SSDs, 1 @ 4TB HDs, Nvidia 2GB Dual Monitor Card, Dual LG 48" TVs used as Monitors, Arturia 88 Midi Controller, Black Lion USB Audio Interface, Mackie HR-828 Monitors, Katana Head, Fishman Triple Play, Win 10 Pro, PT 2023.3 Studio, only the Plugins I NEED, WAY TOO MANY Guitars...and an AMAZING wife! AxeShield HD, AmpShield HD, KeyShield HD, AxeSak, AxeGlove, AxeCap & PedalShield Last edited by LightWing; 01-27-2016 at 04:50 AM. |
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input | yellow | Eleven Rack | 1 | 05-04-2012 03:33 PM |
Setting up a USB/Midi Controller while using a tascam audio/midi interface | disabledpro001 | macOS | 5 | 03-30-2012 07:06 AM |
Midi newb - USB Controller + Midi Keyboard @ same time. | Monty_python | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-26-2008 01:56 AM |
Inexpensive Midi i/o | Media Man | Pro Tools TDM Systems (Mac) | 11 | 10-25-2007 03:31 PM |
What is your favorite inexpensive Keyboard Controller? | jamieorc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-09-2002 02:18 PM |
