Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
  #21
Old 12-05-2020, 05:25 AM
Franklyn Franklyn is offline
Default Re: Side Chain Delay Compensation Issue Fixed?
Originally Posted by thebeatless View Post
It’s not that simple though. If you have plugins on the channel receiving the side chain send, even just the one you want to side chain, there’s also delay that has to be compensated for. Typically if I have a track that I want to side chain, I have to commit/duplicate the side chain source track and insert a time adjuster plugin on that duplicate. Then manually enter the delay time shown on the receiving track. If you change a plugin on that track, make sure you change the delay time. Or... if you change the timing of the actual kick track, make sure you update the duplicate track for the side chain send. I sometimes end up with 5 duplicates of a kick track because of this. I’ve been learning other DAW’s due to the frustration this process causes. So far it seems ok in studio one, cubase, and reaper, but they all have other issues, and I typically receive pro tools sessions from clients.
yes ! exactly !
  #22
Old 12-05-2020, 06:10 AM
danyg danyg is offline
I will double check that but I don't remember having an issue putting plugins on the receive-track
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
  #23
Old 12-05-2020, 09:13 AM
JingleDjango JingleDjango is offline
This has not been addressed, no. If you haven't yet submitted your responses to the ACA vote I suggest writing this feature in.
  #24
Old 12-05-2021, 12:51 AM
Hey thebeatless,
I also testing studio one and cubase at the moment. Because PT has still problems with timebased FX and Midi sidechain. You wrote that those other DAWs all have other issues. Can you explain if S1 or Cubase has any problem with ADC (midid, audio, auxes, timebased FX, ...) or what did you find a problem with these DAW coming from PT. :)
Thanx for an Info ...
Fix Side Chain Delay Compensation NOW please! mattdugred Pro Tools 12 40 01-26-2020 11:10 PM
Side chain delay compensation Macsearcher Pro Tools 2019 10 07-15-2019 10:15 AM
Side chain delay compensation fixed in PT HD 12 using Native card? OliverH Pro Tools 12 5 05-18-2016 08:39 AM
Delay Compensation using Side Chain Oblivion777 Pro Tools 10 4 10-11-2012 01:22 PM
