Old 02-12-2009, 02:42 PM
Kling3 Kling3 is offline
Default Wireless Keyboard/mouse...?
Digi says to disable Bluetooth only if it is causing problems with PT. Anyone using either of these devices without issue?
002r/MacPro 2.8/8-core/10.6.4/PTLE 8.0.4/two internal 500gig drives/8GB ram.
Old 02-12-2009, 03:18 PM
ElectricGhost ElectricGhost is offline
Default Re: Wireless Keyboard/mouse...?
No.
Not under PT8 with a low buffer setting!
With my mighty mouse PT7 worked fine!And 8 works if the buffer is set at about 256ish. With it set at its lowest it gives errors after a short time. Switch bluetooth off and no troubles!
Powerbook G4 12in 1.33ghz 1.25gb ram (Tiger)
Macbook Pro 15in 2.4ghz 4gb ram (Leopard & PT 8LE)
Mbox
Mbox 2
Mbox Micro
Old 02-12-2009, 08:00 PM
Just saved me some money. Thanks.
Old 02-13-2009, 01:40 AM
That is just me with a MacBook pro 2.4,
I'm not sure if anyone else has the same problem?And as I said,it is fine to use when mixing with the buffer set higher. I do like my Bluetooth MM.
Mbox
Mbox 2
Mbox Micro
Old 02-13-2009, 05:37 AM
Will Russell's Avatar
Will Russell Will Russell is offline
I use a wireless keyboard and mouse all day with no problems.
Will Russell
Electric Wilburland Studio
www.wilburland.com
12 core 3.06Ghz MacPro, OS 10.14.5, PT2019.6, HDX, D-Command
Retina 5k iMac OS 10.14.5, PT2019.6, MBox3
Retina MacBook Pro OS 10.14.5, PT2019.6
Old 02-14-2009, 01:21 AM
Yeah but your spec states with PT7.4!as I said no problems with 7, but my Bluetooth is not working right with PT8.
Mbox
Mbox 2
Mbox Micro
Old 02-14-2009, 06:42 AM
JrummerJ JrummerJ is offline
I am using PT8 on a macbook pro 2.2 GHz, and I use the bluetooth keyboard and mouse all the time no problems. I was getting some cpu errors, but they were still there when I disabled bluetooth, so not an issue with the keyboard and mouse.
J
Old 02-15-2009, 03:00 PM
I did quite a bit of testing with my system to find out what was causing the cpu errors. I created 48 audio tracks and set the buffer at its lowest setting with the mbox 2 micro, Armed all the tracks and hit record. The system crashed at various different times with bluetooth on (normally under a minute). With bluetooth switched off I let the system record for close to 4 minutes before I stopped it with no cpu crashes at all. From the tests I did everything pointed to the bluetooth mouse being the problem(with low buffer settings). I know it is a crazy test but I was trying to give it extreme settings. As I said these are just my findings and I'm sure other systems will have different results.
My setup was as follows
Macbook Pro 2.4, 4gb ram
Using internal 7200rpm Seagate 320gb hard drive(partitioned)
(I know it is not suggested but it runs great)
Mbox micro 2
OS10.5.6
PT8LE.
Mbox
Mbox 2
Mbox Micro
wireless keyboard & mouse OKAY? cananball Pro Tools TDM Systems (Mac) 5 10-24-2011 06:11 PM
Wireless Mouse and Keyboard DJKeys macOS 6 08-15-2011 02:35 PM
OS9: Wireless keyboard & mouse Mount Royal Pro Tools TDM Systems (Mac) 1 02-17-2004 12:19 PM
Anyone using wireless keyboard and mouse? Allen Hallada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-01-2004 01:16 PM
Wireless keyboard and mouse? Wolfgang Eller Tips & Tricks 7 11-12-2002 02:11 AM
