Old 01-26-2006, 08:08 PM
OKN OKN is offline
Default XMON
Ok, Sorry if this is a dumb question.
I am looking to ugrade/crossgrade to a ProTools HD system, I was also looking at getting the D-Command console.
I am interested as to how the Xmon works with the ProTools software. Will I need to create a buss that out puts to the Cues? Can I simply do a "Master to cues" type thing to get the backing track to the cues, then add any other incoming signals I wish to be in the cues?
Nornally when tracking, I open up 20 or so tracks, then take and take and take to a new track each time, I find this the easiest way to comp the vocal down to the best take. Can I simply mirror a signal from the input to the cues section, or will I need to set up a send from every channel I wish to record on?
How much latency is there using the Xmon? Is this latency always the same no matter how much processing is going on inside protools even if some of the processing is RTAS?
Thankyou in advance.
OKN
One other thing, Have all the monitoring issues with the XMON been fixed, the dimming staying latched and such.
Old 01-27-2006, 09:19 AM
RichN's Avatar
RichN RichN is offline
Default Re: XMON
Hi OKN,
There are two cue outputs on D-Command, each of which can be fed via switch selection from either the main mix feeding your Control Room monitors or their own dedicated Cue input, which you would typical source from a send via a 192 analog output pair. In order to get a custom headphone mix based on your control room monitor mix, a quick way to do this is to create a stereo cue buss, assign it to one of the sends across the desk, select all channels then do a "copy to send" command to copy your fader mix to the cue sends. Then flip the cue mix down to the faders and tweak the cue mix to your talents liking from the faders.
Xmon does not contribute any latency, it is completely analog. The sticky talkback issues have been addressed via recent Pro Tools software updates.
Rich Nevens
Digidesign
Rich Nevens
Director WW Strategic Audio Sales
Old 01-27-2006, 09:34 AM
SessionKat SessionKat is offline
Default Re: XMON
As well, there are no latency issues monitoring through XMON.
Good luck!
-tv
Tim vdB
Avid Audio
"There's a fine line between stupid and clever."
Old XMon on S6? paulo m Avid S4/S6 15 08-20-2014 03:22 AM
Need XMON help AINSLIE ICON & C|24 9 05-31-2012 11:51 PM
Xmon?? bstroner ICON & C|24 5 04-01-2009 05:47 PM
XMON for your DAW Mike Landolt General Discussion 1 04-13-2006 03:04 PM
XMON tstemland ICON & C|24 2 03-23-2006 02:00 PM
