Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 05-31-2019, 09:42 AM
putney putney is offline
Default Eucontrol download
We have an S5, but I have no download for EuconWS. The most recent we have is 3.6.1.
I was told that if we download pro tools control software to an iPad the Eucontrol download would populate in our account.
I'm not seeing that
Thanks
File Type: jpg Screen Shot 2019-05-31 at 10.31.55 AM.jpg (91.9 KB, 0 views)
"What's the best mic under $100."
Old 05-31-2019, 09:43 AM
MarcOFB MarcOFB is offline
Default Re: Eucontrol download
Eucontrol is for the artist series and the S3 IIRC, the S5 uses EuconWS. Should be in the pckage of files when you download S5 software from your avid acc.
Old 05-31-2019, 09:44 AM
Download the S5 V6 software and it should be in there
Old 05-31-2019, 10:00 AM
BScout BScout is offline
I'm not seeing that
Thanks
You haven't registered the app, it seems. You not only have to download the Control app but you have to open and register it to your account. Then you will see it as Control app but if you open that line, you will see the Unified Installer.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 05-31-2019, 10:01 AM
Eucontrol uses a Unified installer for the last two versions. It includes not only the S3/Artist Mix software but the XMON control, Eucontrol Workstation, and EuconWS software.
Old 05-31-2019, 10:06 AM
I see that, however the euconWS would be the same 3.6.1 as he would get in the S5 V6 dow load. It was my understanding that he needed the euconWS, and was of the impression eucontrol was what he thought he needed for the S5. Which of course sounds confusing now that im reading this to myself :)
However euconWS 3.6.1 IS the latest WS im pretty sure
Old 05-31-2019, 10:13 AM
The latest is EuconWS 4 something
There are now things appearing in 4.x that the System 5 will never support.
But the 3.x versions are old. The merge of Euphonix and Avid for software/products didn't happen smoothly so when they went to the newer version naming system, it wasn't apparent to Euphonix owners (including those who owned the silver Euphonix Artist controllers)
Old 05-31-2019, 10:18 AM
Ah thank you for this cause im still running euconWS 3.6.1 ! Ill be sure to update asap.
Would you happen to know if digital monitoring would work with the SPL Madison? Cause then just 2 of those could substitute my 713 and 703
Old 05-31-2019, 10:29 AM
Think you meant this for the other thread (so as not to get OT on this one) but the Madison is strictly 16 in x 16 out AD/DA (and you can chain 4 to use up the full MADI bandwidth.)
I'm unclear what you mean by "digital monitoring" but if you need AES out or SPDIF out, the Madison does not have this. Only MADI and analog.
If you want that, you might look at the SSL Alpha converter boxes.
Download Artist Mix Firmware from Eucontrol 18.3? sjgam Artist Series 2 10-11-2018 05:56 PM
How to download Eucontrol? Bluto Artist Series 3 09-03-2018 10:18 PM
Can't download EuControl/Workstation 3.4 [SOLVED] andrum Avid S1, S3, Dock and Control 21 05-14-2016 08:04 PM
Eucontrol V3 download Davekey Artist Series 5 08-20-2013 03:14 AM
Download Manager Stalls during download corym macOS 1 01-31-2012 09:19 AM
