Old 08-26-2017, 12:55 AM
Lenedge Lenedge is offline
Default Waves plugins not being seen by protools
Ive purchased many waves plugins, but three I've recently purchased are not being recognised. IU come here for assistance as I've scoured the net for suggestions without any luck.
A- I've rescanned
B - I've emptied plugins folder and restarted protools as per online protocol
C- I've contacted waves and followed their online suggestions.
all have been to no avail, i fear i will need to uninstall and reinstall Protools, which for me is a pain as my Studio is offline, i would need to bring it in the the house and do this.
Is anyone able to assist.
I'm using PT 12.2
The plugins not showing are Aphex AX, Scheps 73 and the H series.
Old 08-26-2017, 01:07 AM
sw rec sw rec is offline
Default Re: Waves plugins not being seen by protools
Did you install the 64-bit AAX versions? That's the only plugin format pt 12 is going to recognize.
Old 08-26-2017, 09:36 PM
Yes 64 bit AAX
Old 08-27-2017, 12:09 AM
peterle peterle is offline
...had same here , reinstalled wave plugins and all was working again.
foley artist , soundeditor
Old 08-27-2017, 11:18 AM
john1192 john1192 is offline
there was an updte to Waves Cental i believe ..
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 08-27-2017, 04:31 PM
Yes I've updated Waves Central.
Did you uninstall & reinstall ALL your waves plugins?
Old 08-27-2017, 04:50 PM
yes
Old 08-27-2017, 09:33 PM
laki laki is offline
I had something similar to this recently. I deleted the PT file which lists the installed plugins on your system. I forget the name of it. It lives in the same folder as your prefs.
Next time I started PT, it asked me where my waves plugin folder is located (not the same as rescanning for some reason)
Worked after that. Hope this helps.
Old 08-27-2017, 11:47 PM
elicious elicious is offline
Your new licenses are not being seen;
go back to waves central and drag your licenses into the proper location
and you should be good...
e
ihatetyping
Old 08-28-2017, 08:21 PM
Sorry for the bum steer here. Actually this is the file that you need to delete:
V9PluginFolder_ScanView.txt it is located here (on OSx)
MacHD/Users/your-username/Library/Preferences/Waves Preferences
It just happened to me today on a different machine.
FS : Plugins alliance, avid, flux, waves plugins, blastwave sound library Roll Buy & Sell 5 03-11-2013 07:20 AM
Waves plugins make ProTools crash! Eydfinn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-25-2012 07:29 PM
HELP with Protools LE 8.0.4 / MBOX3 / Plugins WAVES.. problem Riversound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-05-2011 07:25 PM
Wacom Protools and Waves plugins bob schachner Pro Tools TDM Systems (Mac) 7 03-26-2008 05:28 AM
Protools can't see Waves plugins DMP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 01-04-2003 01:10 AM
