Old 06-18-2007, 06:25 PM
triplethreat23 triplethreat23 is offline
Default Nothing recognizes my Digi 002
My digi 002 has been set up and working for a good 6 months to a year with my computer and suddenly the computer quit recognizing it. I tried a new firewire cable. I tried hooking it up to 2 other computers and nothing. The 1394 light/Stand By mode doesn't even come on. Any ideas?
Old 06-18-2007, 07:29 PM
Default Re: Nothing recognizes my Digi 002
Search for POWER HARNESS as that is likely to be your problem. Does the 002 make a clicking sound?
Old 06-18-2007, 08:30 PM
Sometimes it makes a clicking sound. Thanks for the reply.
Old 06-18-2007, 09:24 PM
spkguitar's Avatar
The clicking sound is one of the indications of the faulty power harness problem. It is an inherent flaw in early production models with serial numbers that end in the letters A thru F. Call Digidesign and they will send you a replacement kit with instructions.
Old 06-19-2007, 11:37 AM
blueviewrecords blueviewrecords is offline
I just had my 002r crap out(6mo. out of warranty) and I've checked out the cable and it's fine as well as power supply.
I also verified that my serial ends with a G so I've got the up to date cable as well and I've got a system with VERY FEW hours on it...Less than 100hrs I'm sure.
The bummer is I've got a project to start on Monday and now am expediting repair thanks to a major problem.
I'm very dissappointed and hope the cost isn't rediculous to swap out a digital/analog board...Regardless, I'm sure the money I make on my project will take a major hit. Not sure if I've made the right choice in systems at this point...
Ohh btw-When i turn the system on, the mute light comes on and it just sits there. No cycle thru sample rates, no "3 clicks" as usual, and no ProTools.
Yours truly,
a disappointed user who wonders if this will happen again!!!!
Scott Patrick
Blueview Records
iMac 2.66 GHz
1GHz system bus
Mac OS X v10.5 Leopard
2GB DDR2 800 SDRAM
320 GB SATA
ATI Radeon HD 2600 Pro
FW 400 & FW 800 port
Old 06-19-2007, 05:59 PM
Try reseating all the connections on the power harness. Odds are very good that you will be up and running in 20 minutes.
Old 06-21-2007, 05:41 PM
Since the Digi 002 is out of commission, is there any way I can use the software without the unit or do I have to reinstall the software? As it is now when the software loads I get the cannot find hardware message with no option other than connecting hardware or canceling launching the application.
Second of all, can I even mix old projects without the 002 if I am able to successfully launch the software?
Help is appreciated.
Old 06-21-2007, 06:06 PM
spkguitar's Avatar
No.
Old 06-21-2007, 06:28 PM
JMS40 JMS40 is offline
Have you tried reseating the harness as albee1952 suggested?
Might try cleaning the contacts with something like De-Oxit too.
002 problem (CoreAudio recognizes it but PT won't) seemikedrum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-26-2013 01:49 PM
PT 9.02 No longer Recognizes Hardware Willard macOS 1 03-15-2011 11:07 AM
external recognizes usb but not eSATA???? greenwood63 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-03-2011 05:41 AM
Mbox only recognizes 1gb ram for buffer channertools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-26-2009 02:22 AM
Other recording software that recognizes TDM hardware? jjungkurth Pro Tools TDM Systems (Mac) 3 07-02-2003 12:32 PM
