Old 11-03-2004, 05:46 AM
thin ice thin ice is offline
Default System software
I just bought a G4 dual 867 mirrordoor Mac from a friend. Tried to install a new system hard drive and load OSX and OS9 as it is a dual boot machine. He could not find the restore disks, but I have at least 5 different sets of restore CDs for other G4s and laptops. Also a system Disk for OS9 which I bought when it first came out. None of these would boot and load. Do I have to have the original restore CDs for a mirror door?
Mac Pro 2.66 Quad-Core Intel Xeon
6 GB 1066 MHz DDR3
HD3 Accel PT 9.0.6, OS 10.6.8
Old 11-03-2004, 11:03 AM
Seeee Seeee is offline
Default Re: System software
you have to do a system restore in osx in order to install os9 BUT in order to do the system restore you have to be RUNNING OSX. you cant boot off the sysytem restore disk.
Old 11-03-2004, 12:28 PM
Chief Technician's Avatar
Yes.
Old 11-04-2004, 08:15 AM
Thanks for the responses. It's a bit off that I cannot load OS9 from an official Apple disk that I bought on it's own. I have now managed to loaded to load 10.2. How would I go about getting OS9 on from my Apple disk?
6 GB 1066 MHz DDR3
Old 11-04-2004, 08:36 AM
SelectSound SelectSound is offline
When we set up our dual boot G4 MDD we had to install OSX first then install 9.2 after that on the same partition. The trick is that our OS 9.2 software came on the same DVD as OS 10.2.8. Even though we wanted to have OS X on one partition and OS 9 on a second partition, we had to install OS 9.2 and OS X on the same partition just to use the system 9 software. It sounds kind of weird but we got the advice directly from apple tech support. The version of OS 9 that they provided with the computer can only work properly when it has OS X installed on the same partition with it.
Old Mix System Software TCLguy1 Pro Tools TDM Systems (Mac) 0 01-22-2009 05:14 PM
Software for used Mix system? pegleg7 Pro Tools TDM Systems (Mac) 4 06-21-2007 10:53 PM
old software for TDM system luckykris Pro Tools TDM Systems (Mac) 1 10-25-2004 07:23 PM
5.1 software on a PT's 3 system? Seeee Pro Tools TDM Systems (Mac) 7 10-31-2003 06:43 PM
system software update? amateur tool 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-12-2001 11:59 PM
