Old 03-25-2003, 07:41 AM
D Clarkson D Clarkson is offline
Default Drum overhead-problems
I have a problem with low ceilings when it comes to recording drums;the cymbals sound so trashy,and it seems that everything on the overheads is boosted at 2/2.5 Khz.
Normally I don't have that problem when I'm recording in a room with a ceiling that's 20 ft. high.But the room I'm recording now is just above 7 ft.
Can anyone help me out?
[img]images/icons/frown.gif[/img]
Old 03-25-2003, 07:50 AM
Mike Tholen Mike Tholen is offline
Default Re: Drum overhead-problems
I would toss a couple of ribboons on the kit and see what happens.
Beyer 260's are nice sounding and cheap.
Coles 4038's are quite a bit thicker sounding and are still relatively cheap.
what mics are you using?
Old 03-25-2003, 07:51 AM
bassmac bassmac is offline
I've got 7' ceilings too. I put the mic's behind the kit instead, sounds great. Also, using cymbals that don't sound harsh themself should be the first step - usually the thinner ones.
Old 03-25-2003, 08:44 AM
Chris Coleman Chris Coleman is offline
You may also want to try a couple PZM mics on the ceiling...worth a shot.
It's not rocket surgery
Old 03-25-2003, 03:10 PM
AE AE is offline
Is the room fairly live? Strong reflections, perhaps from the ceiling, may have a high enough level relative to the direct pick-up to produce phase cancellation. If so, deaden the offending surfaces or move the mics closer. Also, if you have strong reflections, you may have coloration due to the less-than-ideal off-axis frequency response of your directional mics. This can be fixed by using omnis, but you'll also get more of the room which I'm guessing will not be desirable.
Old 03-25-2003, 05:52 PM
centerstage centerstage is offline
Try micing the cymbals off axis. Don't point the mic directly at them. Point them so they catch the cymbals. Make sure there are dead surfaces in the direction the mic is pointed. I've tried to get good sounds from all types of pres...api, neve, daking, avalon...etc...it's hard with low ceilings. Better when the drummer has the kit lower and doen't hit to hard. You might want to put pads on the mics or in the case of the 414's put them on. That can overload and sound like **** . Best of luck.
Tim
Old 03-26-2003, 12:21 AM
Thanx for the replies!
The crashes that I use are 2 K-Zildjians and 1 A-Custom.
I've been experimenting with AKG-C451,and 414.
What's the difference in placing the mics overhead or behind the kit?
I usually place them overhead,but then I get that harsh sound,cuz there's a low ceiling.
I guess if I place them behind the kit,the mics pick up the sound from the entire kit,don't they?
What I also would like to try is to place 2 condensers in front of the kit,about 10-12 feet away to record the "room" and then use Altiverb to make the room sound bigger,however if I place 2 mics in front of the kit,and 2 mics behind the kit,don't they jump out of phase then?
Please advise!
Old 03-28-2003, 01:55 PM
O.G. Killa's Avatar
O.G. Killa O.G. Killa is offline
Have you tried treating the room yet? Look around for "Do It Yourself" types of webpages for acoustic treatment.
One thing I would try is to take a thick blanket or tapestry and hang it above the drumset. Tack it into the ceiling so that it's centered over the cymbals and let it drape down a little bit. It would have a convex curve off the ceiling. Kinda like this (side view)
\__/
but obviously more rounded. Leave the sides open (attach the top and bottom sides to the ceiling leave the left and right sides open. If the tacks/nails are strong enough, you can try to fill it with some sort of light material (fiberglass, sponge, foam, etc). Try Adjusting the amount of draping it has (a couple inches off the ceiling to a foot or two off the ceiling at the lowest point). See what sounds best in the mics.
Theoretically speaking, the wavelength for a sound at 2KHz~2.5KHz is around 4.5~5.5 inches. So you should have the tapestry drape at least 5 or 6 inches off the ceiling to catch sound at 2KHz and up.
Hope this helps a little.
Derek Jones
Sound Engineer / Producer / Composer
Derek Jones Linkedin
Megatrax Recording Studios
Megatrax Studios Yelp Page
A-list Music Artist Page
Old 03-29-2003, 06:24 AM
Thanx for all the tips!
I just found a site/company called Auralex.
I guess they can help me out;all I have to do is to make a "floorplan" of my room,what materials are on the floor,walls ceiling,etc,and what kind of frequencies are disturbing,like too boomy,or flutternoise.Then they will give me advise on how I can absorb,diffuse,or use basstraps,etc!
Great site! [img]images/icons/grin.gif[/img]
Old 04-03-2003, 04:55 PM
Guy McDude Guy McDude is offline
<font size="2" face="Verdana, Arial">I would get some diffusion on the ceiling above the kit.
take care
Best,
Sean
Sean McDonald
Red Medicine Recording LLC
Sofa King Music Services
http://www.seanmcdonald.com
Drum Overhead Mics firsty33 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-03-2011 01:19 AM
Drum overhead suggestion WRX07 General Discussion 8 03-14-2005 07:52 PM
drum overhead question mbuono Tips & Tricks 8 02-18-2004 10:54 AM
drum overhead question mbuono 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-28-2003 10:00 AM
Drum OverHead Tips Kipsey Tips & Tricks 4 03-07-2003 09:29 PM
