Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 06-06-2019, 11:48 PM
the19thbear the19thbear is offline
Default Avid link showing plugins i dont own.
Under "products", i get a long list of uninstalled products that i don't have licenses for.
What is up with that?
That happened to me on 2 different accounts.
How is the avid link useful then? Is there a hidden setting or something?
Thanks
Old 06-12-2019, 12:51 AM
Default Re: Avid link showing plugins i dont own.
Am I the only one seeing this?
Old 06-12-2019, 12:55 AM
jeffro's Avatar
jeffro jeffro is offline
It should be showing what's in your Avid account. If not, we should get more info to check this out.
linkedin
Old 06-12-2019, 03:43 AM
(dont know why i cant show the image instantly, you will have to click the link).
In the top part of the picture you can see what license i actually have.
In the lower part under "Product details...." you can see all the plugins that are showing in my avid link. I don't have licenses for all of those. Only the Pro Limiter.
Thanks
Old 06-12-2019, 05:13 AM
tetonica's Avatar
tetonica tetonica is offline
Any plugin installed in the past leaves an .XML file under Library>Application Support>Avid>CustomDataAppMan
Delete the .XML files of the plugins that you uninstalled and after restarting Avid Link it will show only what is left
Old 06-12-2019, 06:04 AM
Ok. Thanks, will try:)
What is the path on windows?
Thanks a lot
Old 06-12-2019, 06:13 AM
tetonica's Avatar
What is the path on windows? Thanks a lot
You're welcome - not sure what is the path on windows but you could do a search for one of your plugins name with the .xml extension (eg: "Aphex Systems Bundle.xml" "XPand II.xml") and you would find the folder - good luck!
Old 06-12-2019, 10:14 AM
Found it. Thanks
Avid Link not showing correct PT 2019.5 install status taylor4814 Pro Tools 2019 1 05-18-2019 09:11 AM
Avid Link 19.4 not showing an updated version of Falcon availbale freewind1974 Licensing & Accounts 1 05-13-2019 10:52 AM
Avid Application Manager not showing all Avid Plugins quincy_j_clomo Licensing & Accounts 1 01-19-2018 09:18 AM
11.3.1 installer link not showing ktwtd2 Pro Tools 11 3 03-22-2015 09:45 AM
D-fx , Lo-fi, Sci-fi etc. plugins dont work voltech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-06-2002 08:11 AM
