M BOX plug and play detection
When I plug in my M-Box to a newly installed OS, it doesn't detect it properly like it did before I reformatted.
Does anyone know what this is from, or how I can fix it? Are there any drivers that I need? I can't seem to figure out how the settings would have been different before the new OS install Thanks for your time Mark Brewster [email protected] |
Re: M BOX plug and play detection
I am running out of ideas, any help would be greatly appreciated if anyone has an idea
thanks Mark |
does anyone from digidesign offer any help whatsoever? do you even care about your customers?
You reformatted your harddisk. I suggest you install ptle. With the digi001 it only gets discovered during the install....i suppose with the mbox its the same.
What's that? - That's the machine that goes "pling". Bastiaan |
Don't forget that this is the "User" conference, not Digi tech support. As Bastiaan said, try reinstalling the PTLE software. If that doesn't help, and you're looking for a direct contact to Digi, try here: http://www.digidesign.com/support/ Good luck |
Mark,
Are you plugging your cable into the same usb port as before? In my case, I have 4 usb ports, but there is only one port that the MBox will work in. I guess the others are hubs? Also, reboot, enter BIOS, and make sure your usb is enabled. I know the other guys are only trying to help, but you have to get the new hardware window to pop up before installing ProTools with the MBox. Good Luck, Mitch |
thanks for all your help, but none of these are fixing the problem. my comp is old, i am buying a new one tonight, that will hopefully help, LOL
Mark |
What do you consider old?
tempo detection | Darryn Farrugia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-26-2009 09:36 AM |
Beat Detection | March314 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-16-2005 07:42 AM |
Tempo detection and fx loop | n3xus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-12-2004 07:59 PM |
Wacky detection of IDE devices ??? | genebadd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 03-11-2003 09:57 AM |
WAV length detection | airon | Digidesign Hardware & Software | 2 | 01-15-2001 07:05 AM |
