MIDI sustain problem
I'm trying to figure out why the sustain drops out in a section of a MIDI piano recording. The sustain pedal was held down properly during the recording, but as I played it I heard that the sustain was not being recorded, and on playback it's the same.
Re-recorded it and the same thing happened -- the sustain is being turned off for just one measure on the piano track. The rest of the recording with sustain is normal. Using Ivory 1.6. The MIDI event list shows nothing unusual that I can see -- the sustain is on for the entire section in question. Can anyone tell me how can I identify what's causing this?
PT LE 7.4.2/Mac Pro 2.8 Ghz 8 Core/10Gb RAM/OS X 10.5.8/Mbox 2 Pro/MIDISport 4x4/Roland XP-50/Yamaha P-140 Last edited by djcream; 09-08-2013 at 01:47 PM. |
Re: MIDI sustain problem
Hi, sorry I don't know the answer to your question but I have a question in regards to sustaining on midi also. I've searched everywhere and can't find a solution so my apologies. I am completely new to pro tools and I am wondering how to actually put sustain on a midi track and bind it to a sustain pedal which is plugged into my midi controller.
Thanks in advance |
I'm no pro obviously, but if you mean you want to apply sustain to an existing MIDI track I would:
Open the "sustain" view of that MIDI track: To do this you would access the drop down menu's sustain view by clicking on the button that says "notes" on the left side of the track, drop down to > controllers > sustain. Then I would use the grabber tool (the little hand icon top left of the edit window) to manually create the sustain by pulling the black line on the bottom of the track up and down with the grabber tool. When the sustain line is pulled up it's as if you've pressed the sustain pedal, and when it's pulled back down, you're releasing the sustain pedal. Hope this helps. And my question is still open if anyone has any ideas for me...
PT LE 7.4.2/Mac Pro 2.8 Ghz 8 Core/10Gb RAM/OS X 10.5.8/Mbox 2 Pro/MIDISport 4x4/Roland XP-50/Yamaha P-140 |
Problem with MIDI Merge on - sustain events | ChrisSimon | MIDI | 13 | 10-18-2017 02:57 PM |
Help midi sustain problem | weezamiah | MIDI | 3 | 05-21-2014 03:21 PM |
MIDI Sustain Problem In Playback | digijohn | macOS | 2 | 06-11-2013 06:27 AM |
Serious problem! piano sustain pedal controls tap tempo through midi! | gvees | Eleven Rack | 1 | 07-28-2012 03:54 PM |
Problem with recording MIDI piano sustain pedal | Chris7514 | MIDI | 5 | 06-11-2008 12:56 AM |
