convert 16 bit to 24 and sample rate
The concert soundboard audio I received is in 16 bit 44.1khz Is there a way to convert it to 24 bit 48000khz? My camera audio was recorded in 24 bit 48000khz and I need to blend the camera audio and the soundboard audio together and can't without the sample rates being the same.
Thanks, Bryce
Macbook Pro Mac OS 10.10.3 Mbox 2, Pro Tools 11 |
Re: convert 16 bit to 24 and sample rate
Easy. Create a new session at 24 bit/48K and import session data from the original and let PT convert on the way in
Did that but now the vocal track is sped up. The guy sounds like he's pitched up higher. If I leave it at 44.1 it sounds normal. This can't be right
You have to make sure you select the convert sample rate tab when you import the audio.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Exactly^^^^ You didn't convert, so you now have a 44.1K file that is playing back at 48K, which pushes speed and pitch up. In the Import Audio window, find the file you want, click on it once(not twice) and then click the CONVERT button.
I definitely clicked convert.
These are my settings I have.
192 Sample Rate Convert | Touchwood Studios | Pro Tools HDX & HD Native Systems (Mac) | 1 | 08-21-2012 03:51 PM |
Sample rate convert when bouncing.. | ghost22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-04-2007 12:10 PM |
convert sample rate stamp? | whosmatt | Pro Tools TDM Systems (Mac) | 2 | 06-05-2006 06:23 PM |
Sample Rate Convert Questions | Siegfried Meier | Pro Tools TDM Systems (Mac) | 3 | 02-13-2005 07:57 PM |
BTD only way to convert to 44.1M sample rate? | el biciclista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 07-19-2001 03:26 PM |
