Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
  #111
Old 08-25-2017, 07:48 AM
chefbrody chefbrody is offline
Default Re: "You are trying to run a newer version of Pro Tools than allowed" error
Yeah. I would especially like to get the right authorization...
Nicolas
  #112
Old 09-05-2017, 05:25 PM
jeffro's Avatar
jeffro jeffro is offline
Originally Posted by chefbrody View Post
ARGH. I'm stuck. I installed 12.8.1 today and Pro Tools won't open because of my Release Limit Date that is incorrect... I still own an upgrade plan for Pro Tools 12 HD until 03/31/2018 but it indicates 04/01/2017 on my Pro Tools HD "Perpetual" bundle in iLok Licence Manager... And I just can't download anymore 12.7.1 that would work because it's no longer available in my account. Only 12.8 and 12.8.1 that I can't open. ARGH. i opened a case in Avid Support 3 hours ago and still waiting...
Can't locate Avid or iLok accounts or any support cases based on your User Name or email. Did this get resolved?
• linkedin •
  #113
Old 11-18-2017, 01:12 AM
Lydbildet Lydbildet is offline
Default Re: "You are trying to run a newer version of Pro Tools than allowed" error launching
Hi!
My first post here, and I have the same issues as so many others...
My Pro Tools-system is sometimes working, and sometimes not allowing me to even start the program. If I try to open Pro Tools, I either get a message saying "you're trying to run a newer version..." or there are other errors. Like the one on the attached photo. I can't find any solution to this error message anywhere in this thread.
Don't find how to post an image, so I'll retype the error message:
Pro Tools Perpetual could not be loaded. Please contact the software publisher for support using this software.
Error details:
kEEPROM_DataCRCErr967
I have tried to re-activate my license on the ilok, and have a current Application Manager.
I have a deadline for a project on monday, and right now I can't get to work...
  #114
Old 11-18-2017, 04:15 AM
Originally Posted by Lydbildet View Post
Hi!
Error details:
There are a couple of ways to attach a screenshot. In the bar above the box where you type your responses there is a paperclip icon which will allow you to upload an attachment which can be a graphic and there's also an icon that has the popup tag of 'insert image'. The first option is for a graphic that is on your computer and the second is for something hosted on an online service to which you provide a hyperlink.
Back to your problem:
Does your computer have USB3 ports? If so those have been known to have issues with an iLok. Usual remedy is a powered USB hub between the iLok & computer.
And that brings up the second issue and is related to power. Windows computers tend to have power savings measures enabled by default on both laptops & desktops for the USB ports. Make sure those are turned off in Windows Control Panel. iLok needs to be plugged in to an always powered on USB port whenever working in PT.
Lastly - make sure you have the right iLok license asset for your version of PT. Something Avid started with PT12 is when there's a new version you may have to download a new license asset to your iLok. You don't say what version of PT you're trying to run.
Jack
QAPLA!
  #115
Old 11-18-2017, 06:50 AM
I have deactivated power saving in my control panel a long time ago.
I am having major iLok-issues right now as well, since my iLok that I purchased brand new from a dealer shows up in the license manager with a totally different name and with a series of activatons and licenses that I have no knowledge of. I have registeret support tickets with iLok, but despite my ZDT-plan I am now facing downtime... But, my iLok-account with my Pro Tools-license was registered in my license manager when I got the error message shown in the attached photo.
I have been able in the past to unplugg and plug in my iLok a few times to make the mystery ID disappear and my iLok active. But today I have no such luck.
I try to run Pro Tools 12.8.2, and I have had these issues both with "you are tring to run.." and error-messages when trying to open Pro Tools ever since upgrading to PT 12.8.
In fact, I have not once been able to fire up my computer and open Pto Tools without spending an hour or so working my way around various error-meesages from the system, either with messages like "you are trying.." or iLok-related issues where the two systems, Pro Tools and iLok for some reason never seem to recognize and accept one another..
  #116
Old 11-18-2017, 08:43 AM
Zero Downtime only refers to a case if your iLok is broken somehow. Being you can access the iLok doesn't fall under that. Can you post a screenshot of what the ILM s/w shows? That might help things along.
Jack
QAPLA!
  #117
Old 11-18-2017, 09:10 AM
Thank you for your reply, musicman691!
See the attached screenshots.
No. 1 is taken after I first start ILM.
No. 2 shows what happens when I plug in my iLok2.
No. 3 shows information about the account that I don't recognize
No. 4 shows information about my account that is not active.
  #118
Old 11-18-2017, 09:13 AM
Southsidemusic's Avatar
Can't see what the text shows on those wishy washy pictures. Too blurry.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #119
Old 11-18-2017, 09:29 AM
BScout BScout is offline
Looks like you have an expired plan that was expired before 12.8.2 came out.
  #120
Old 11-18-2017, 09:32 AM
Also looks like the iLok key with your license isn't plugged in.
The red ilok is one NOT registered to your (which does seem to be plugged in but without the right licenses.) It appears to have SSL Duende licenses only.
Pro Tools 10 won't open session file (Created on a newer version) sjafarzadeh Pro Tools 10 8 06-14-2023 11:24 AM
This session file was created by a newer version of Pro Tools [7.4.2f109] olivergodfrey Pro Tools M-Powered (Mac) 3 02-12-2013 04:53 AM
unable to install bfd lite for pro tools 8 beacause newer version already exists? Digitopian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 04-25-2009 12:00 PM
