Old 08-12-2017, 02:06 PM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
Default Update DIGI002 Rack Drivers?
As you can see from my details, I have a pretty old PT system, but it works pretty good for what I do. The only issue I occasionally have is the "System Held off Interrupts for too Long - try increasing the hardware buffer size" error.
I never get the error at 512 samples. Occasionally at 256 samples and pretty frequently at 128 or 64 samples. I have 4 processors selected for RTAS processors and CPU usage limit of 99%. Over the years I have messed around with the number of processors and CPU usage limit, but without much effect.
I looked at my driver version for the DIGI002 rack in Control Panel/Sounds and Audio devices and it is version 7.4.0.309 dated 10/31/2007. I noticed the most recent version available from Avid (for the 002) is version 9.0.2.65 dated March 11, 2011. I don't know if this version is for Windows XP SP3 which I am running, or if the hardware buffer size error has anything to do with the 002 or it's drivers.
Any pros/cons of updating my DIGI002 drivers to the latest Avid offers?
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 08-12-2017, 02:22 PM
No deep comment here, but I would try increasing RTAS CPUs to 5 just to see if that helps overall--it likely won't help with this problem, but you have 6 cores in that CPU you can try throwing 5 of them at plugins.
What FireWire card do you have? The interrupt error is often associated with Firewire. Move any storage or other peripherals off FireWire. Get a new USB or similar interface. Try upgrading drivers, sure if it's supported--it is trivial to go back.
Post a Sandra report and we can see if anything else is obvious.
Old 08-12-2017, 02:49 PM
Default Re: Update DIGI002 Rack Drivers?
Thank you for the response Darryl. I just created a new session with 1 mono audio track and 1 stereo master fader. Imported (using copy) a single audio track from another session. No plugins on any track. Tried hardware buffer size of 256 samples and it plays back for about 20 seconds before throwing the error message. 48k, 24 bit session.
CPU utilization of 5% or less. No other applications running. Have done all of the Avid recommended optimizations. There is one external HDD connected to my firewire card, but the device is off. I only turn it on when not using PT and do some backups to it.
I am not sure which firewire card I have (it came with a Sweetwater build I had long ago and have it installed in my current rig, so I assume they used an approved one). Per device manager it says "Texas Instruments OHCI compliant IEEE 1394 Host Controller".
I may try installing the latest DIGI002 drivers, as I have already downloaded them. I presume I could successfully roll back to previous drivers if they don't work, and I also just made a backup image of my OS drive using Acronis True Image Home.
As for the Sandra report, my PT computer is not connected to my home network, so I will probably have to download the program on my main computer and run it on the PT rig, if it works that way?
Old 08-12-2017, 03:44 PM
Looking at CPU utilization is not likely to tell you much , and it's low as expected with no plugins instantiated. The #CPU comment was more a general suggestion for large CPU hungry sessions.
TI FireWire chipset is good and the main question I had. A Sandra report would still be nice. Just download the Sandra installer and move to your DAW PC and you can copy back the Sandra report or copy and paste the text you need into any app.
Recheck *every* optimization is done, no Bluetooth, no WiFi, unplug every USB and FireWire device you can, etc. etc, every last thing done while you troubleshoot. You already likely know the community does not have lots of coverage on these AMD processors and chipsets so you are somewhat on your own. Competition is good and I hope we see lots more folks playing with the new AMD Rizen and Threadripper (but lack of Thunderbolt support is a issue for me).
Old 08-12-2017, 03:59 PM
I will try generating the Sandra report tomorrow. I will have to watch the tutorial video first as I have never run the Sandra software and it has been a long time since I looked at the tutorial.
It's possible that my firewire card is going bad because it is 10+ years old, but I can loop playback the section of audio indefinitely at 512 sample size buffer.
Getting ready to watch some football! (Canadian football league on ESPN3, but it is still football).
Old 08-13-2017, 07:32 AM
Bad news on 2 fronts!
I installed the latest drivers for the DIGI002 and tried to launch PT, and it said no Digidesign hardware found. I confirmed that the drivers I intended to install were indeed installed for the DIGO002 rack. So I went to roll back to previous drivers and it said no drivers were backed up. Not good. I guess installing the latest drivers overwrote the old ones.
Luckily I had made a disk image of my C drive last night before messing around with the drivers, so I restored from that disk image, and now the old drivers are there and PT launches and works again.
As for the Sandra report, I downloaded the software onto my Windows 8.1 Professional computer and installed the software and successfully ran the overview report after looking at the short tutorial video, just to know which report to run. Copied the downloaded Sandra.exe file to a thumb drive and inserted it into my PT computer, exited out of all open programs and tried to run the software. Got a message saying "This program does not support the version of Windows your computer is running".
I did not see a legacy version of the Sandra software on their website. Other than the paid versions I only saw one download option, which is the one I chose. Sandra - lite or something to that effect.
Just to verify I was on the correct download site, this is the link:
http://www.softpedia.com/get/System/...e-Sandra.shtml
Any other advice/suggestions?
Old 08-13-2017, 10:37 AM
The Weed's Avatar
The Weed The Weed is offline
Try Speccy from Piriform. It may be that the downloader sensed your operating system on your Internet computer and you got a version for W8.1. May or may not be the case with Speccy, which has a free version. Belarc Advisor is also good, but I don't think it provides just a computer overview.
BTW, how did you get interested in the CFL? Or is that just to tide you over until College and NFL football season?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-13-2017, 11:56 AM
Ya, maybe that is what happened. I could temporarily connect my PT computer to the network and download it again and see what happens, although when I went to their FAQ section and looked at compatibility it only mentioned Windows 7 and up. I Googled Sandra for Windows XP and there were quite a few download sites, but I don't know if I should trust them to not download a bunch of other crapware along with the Sandra software.
I started watching the CFL last year mainly to tide me over until College and NFL started (not the preseason NFL, which is a joke), but found myself interested in the Canadian game due to the 3 downs rather than 4 which makes for a pretty exciting pace of the game. Plus there are some ex-NFL players that I like to follow. I think Toronto has an ex Houston Texans receiver (DeVier Posey), but he got injured in the first game or two. Calgary has a QB from the Houston area (Katy, TX), Bo Levi Mitchell.
Old 08-13-2017, 05:03 PM
The Weed's Avatar
Lot of players went to the CFL from the NFL and vice versa. Doug Flutie and Warren Moon two of the biggest names. Coaches and GMs too. Hugh Campbell and Marv Levy come to mind along with Forrest Greg. The 3 downs, longer wider field, huge end zones, 12 men versus 11, single point, motion during the snap and no yards instead of a fair catch are the major differences - and do take some getting used to. On the other hand, the Grey Cup - the championship game - is almost always more exciting than the Super Bowl. And there's only one week to wait for it instead of two
As I mentioned above, try Speccy.
SonoBus
Old 08-14-2017, 07:36 AM
OK, here is the Speccy report, I think I have included the relevant information from most all of the tabs. On some screens it mis-identifies my processor as a 1040T, when in fact it is a 1045T. Also the motherboard's chipset is identified as 780G, when in fact it is a 760G. It doesn't identify my firewire card in the PCIe slot, perhaps because my Digi002 is turned off.
One thing I did notice was my CPU frequency was at 800mhz, when it should be at 2700mhz. CPU-Z also showed it at 800mhz, so I went into AMD Overdrive and set the multiplier at default (13.5) and saved the settings. I don't know how the cpu was set to downclock itself when all of the processing power isn't needed, but I re-booted and it is now at a steady 2700mhz.
Speccy Report:
Operating System
Windows XP Home Edition 32-bit SP3
CPU
AMD Phenom II X6 1040T
Thuban 45nm Technology
RAM
4.00GB Dual-Channel DDR3 @ 666MHz (9-9-9-24)
Motherboard
Gigabyte Technology Co. Ltd. GA-78LMT-S2P (Socket M2) 47 °C
Graphics
CMC 22 W (1680x1050@60Hz)
Default Monitor (1680x1050@60Hz)
SDM-HS95 (1680x1050@60Hz)
CMC 22 W (1280x1024@60Hz)
Default Monitor (1280x1024@60Hz)
SDM-HS95 (1280x1024@60Hz)
256MB NVIDIA GeForce 7600 GT (BFG Tech) 62 °C
Storage
74GB Hitachi HDS728080PLA380 (SATA) 38 °C
1863GB Seagate ST2000DM001-9YN164 (SATA)
7GB USB Device (USB)
Optical Drives
PLDS DVD-ROM DH-16D5S
Audio
No audio card detected
Operating System
Computer type: Desktop
Installation Date: 6/15/2012 12:30:28 AM
Serial Number: xxxxxx
Windows Security Center
Firewall Disabled
Windows Update
AutoUpdate Disabled
Antivirus
Antivirus Disabled
Company Name Microsoft Corporation
Display Name Microsoft Security Essentials
Product Version 4.2.223.1
Virus Signature Database Up to date
.NET Frameworks installed
v4.0 Client
v3.5 SP1
v3.0 SP2
v2.0 SP2
v1.1 SP1
Internet Explorer
Version 6.0.2900.5512
PowerShell
Version 2.0
Environment Variables
USERPROFILE C:\Documents and Settings\Mike
SystemRoot C:\WINDOWS
User Variables
Machine Variables
Power Profile
Hibernation Disabled
Turn Off Monitor after: (On AC Power) 300 min
Turn Off Hard Disk after: (On AC Power) Never
Suspend after: (On AC Power) Never
Screen saver Disabled
Uptime
Current Session
Current Time 8/14/2017 8:56:18 AM
Current Uptime 2,617 sec (0 d, 00 h, 43 m, 37 s)
Last Boot Time 8/14/2017 8:12:41 AM
Services
Running Acronis Scheduler2 Service
Running Application Layer Gateway Service
Running Automatic Updates
Running COM+ Event System
Running Computer Browser
Running Cryptographic Services
Running DCOM Server Process Launcher
Running DHCP Client
Running Digidesign MME Refresh Service
Running Distributed Link Tracking Client
Running DNS Client
Running Error Reporting Service
Running Event Log
Running Fast User Switching Compatibility
Running Help and Support
Running HID Input Service
Running IPSEC Services
Running Microsoft Antimalware Service
Running Network Connections
Running Network Location Awareness (NLA)
Running NVIDIA Driver Helper Service
Running NVIDIA Update Service Daemon
Running PACE License Services
Running Plug and Play
Running Print Spooler
Running Protected Storage
Running Remote Access Connection Manager
Running Remote Procedure Call (RPC)
Running Remote Procedure Call (RPC) Locator
Running Secondary Logon
Running Security Accounts Manager
Running Security Center
Running Server
Running Shell Hardware Detection
Running SSDP Discovery Service
Running System Event Notification
Running Task Scheduler
Running TCP/IP NetBIOS Helper
Running Telephony
Running Terminal Services
Running Themes
Running WebClient
Running Windows Audio
Running Windows Firewall/Internet Connection Sharing (ICS)
Running Windows Management Instrumentation
Running Windows Search
Running Windows Time
Running Wireless Zero Configuration
Running Workstation
Stopped .NET Runtime Optimization Service v2.0.50727_X86
Stopped Alerter
Stopped AODService
Stopped Application Management
Stopped ASP.NET State Service
Stopped Ati HotKey Poller
Stopped Background Intelligent Transfer Service
Stopped Bonjour Service
Stopped ClipBook
Stopped COM+ System Application
Stopped digiSPTIService
Stopped Distributed Transaction Coordinator
Stopped Extensible Authentication Protocol Service
Stopped Health Key and Certificate Management Service
Stopped HTTP SSL
Stopped IMAPI CD-Burning COM Service
Stopped Indexing Service
Stopped InstallDriver Table Manager
Stopped Intel Integrated Clock Controller Service - Intel ICCS
Stopped LMIGuardianSvc
Stopped Logical Disk Manager
Stopped Logical Disk Manager Administrative Service
Stopped Messenger
Stopped Microsoft .NET Framework NGEN v4.0.30319_X86
Stopped MS Software Shadow Copy Provider
Stopped Net Logon
Stopped Net.Tcp Port Sharing Service
Stopped NetMeeting Remote Desktop Sharing
Stopped Network Access Protection Agent
Stopped Network DDE
Stopped Network DDE DSDM
Stopped Network Provisioning Service
Stopped NT LM Security Support Provider
Stopped Performance Logs and Alerts
Stopped Portable Media Serial Number Service
Stopped QoS RSVP
Stopped Remote Access Auto Connection Manager
Stopped Remote Desktop Help Session Manager
Stopped Removable Storage
Stopped Routing and Remote Access
Stopped Smart Card
Stopped System Restore Service
Stopped Uninterruptible Power Supply
Stopped Universal Plug and Play Device Host
Stopped Volume Shadow Copy
Stopped Windows CardSpace
Stopped Windows Driver Foundation - User-mode Driver Framework
Stopped Windows Image Acquisition (WIA)
Stopped Windows Installer
Stopped Windows Media Player Network Sharing Service
Stopped Windows Presentation Foundation Font Cache 3.0.0.0
Stopped Windows Presentation Foundation Font Cache 4.0.0.0
Stopped Windows Remote Management (WS-Management)
Stopped Wired AutoConfig
Stopped WMI Performance Adapter
TimeZone
TimeZone GMT -6:00 Hours
Language English (United States)
Location United States
Format English (United States)
Currency $
Date Format M/d/yyyy
Time Format h:mm:ss tt
Scheduler
8/20/2017 1:32 AM;At 1:32 AM every Sun of every week, starting 2/9/2015 Microsoft Antimalware Scheduled Scan
Hotfixes
System Folders
Process List
Security Options
Device Tree
ACPI Multiprocessor PC
Microsoft ACPI-Compliant System
ACPI Fixed Feature Button
ACPI Power Button
AMD Phenom II X6 1045T Processor
Microsoft Windows Management Interface for ACPI
System board
PCI bus
CPU
Cores 6
Threads 6
Name AMD Phenom II X6 1040T
Code Name Thuban
Package Socket AM3 (938)
Technology 45nm
Specification AMD Phenom II X6 1045T Processor
Family F
Extended Family 10
Model A
Extended Model A
Stepping 0
Revision PH-E0
Instructions MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, AMD 64, NX, VMX
Virtualization Supported, Enabled
Hyperthreading Not supported
Fan Speed 1985 RPM
Bus Speed 200.0 MHz
Rated Bus Speed 1999.9 MHz
Stock Core Speed 3200 MHz
Stock Bus Speed 200 MHz
Caches
L1 Data Cache Size 6 x 64 KBytes
L1 Instructions Cache Size 6 x 64 KBytes
L2 Unified Cache Size 6 x 512 KBytes
L3 Unified Cache Size 6144 KBytes
Cores
Core Speed Multiplier Bus Speed Rated Bus Speed Threads
Core 0 2699.9 MHz x 13.5 200.0 MHz 1999.9 MHz APIC ID: 0
Core 1 2699.9 MHz x 13.5 200.0 MHz 1999.9 MHz APIC ID: 1
Core 2 2699.9 MHz x 13.5 200.0 MHz 1999.9 MHz APIC ID: 4
Core 3 2699.9 MHz x 13.5 200.0 MHz 1999.9 MHz APIC ID: 3
Core 4 2699.9 MHz x 13.5 200.0 MHz 1999.9 MHz APIC ID: 2
Core 5 2699.9 MHz x 13.5 200.0 MHz 1999.9 MHz APIC ID: 5
RAM
Memory slots
Total memory slots 2
Used memory slots 2
Free memory slots 0
Memory
Type DDR3
Size 4096 MBytes
Channels # Dual
DRAM Frequency 666.6 MHz
CAS# Latency (CL) 9 clocks
RAS# to CAS# Delay (tRCD) 9 clocks
RAS# Precharge (tRP) 9 clocks
Cycle Time (tRAS) 24 clocks
Bank Cycle Time (tRC) 33 clocks
Command Rate (CR) 1T
Physical Memory
Memory Usage 11 %
Total Physical 3.25 GB
Available Physical 2.87 GB
Total Virtual 3.69 GB
Available Virtual 3.32 GB
SPD
Number Of SPD Modules 2
Slot #1
Slot #2
Motherboard
Manufacturer Gigabyte Technology Co. Ltd.
Model GA-78LMT-S2P (Socket M2)
Version x.x
Chipset Vendor AMD
Chipset Model 780G
Chipset Revision 00
Southbridge Vendor AMD
Southbridge Model SB700
Southbridge Revision 00
System Temperature 48 °C
BIOS
Brand Award Software International Inc.
Version F3
Date 10/18/2012
Voltage
CPU CORE 1.272 V
MEMORY CONTROLLER 1.476 V
VIN2 2.040 V
VIN3 1.632 V
VIN4 1.956 V
VIN5 2.220 V
VIN6 2.220 V
VIN7 1.680 V
PCI Data
Slot PCI
Slot Type PCI
Slot Usage Available
Bus Width 32 bit
Slot Designation PCI
Characteristics 5V, 3.3V, PME, SMBus
Slot Number 0
Slot PCI
Slot Type PCI
Slot Usage Unknown
Data lanes x16
Slot Designation PCI Express x16
Characteristics 3.3V
Slot Number 1
Slot PCI
Slot Type PCI
Slot Usage Unknown
Data lanes x1
Slot Number 2
Manufacturer NVIDIA
Model GeForce 7600 GT
GPU G73
Device ID 10DE-0391
Revision A2
Subvendor BFG Tech (19F1)
Series GeForce 7
Current Performance Level Level 0
Technology 90 nm
Die Size 125 mm²
Transistors 177 M
Release Date 2006
DirectX Support 9.0c
DirectX Shader Model 3.0
OpenGL Support 2.0
Bus Interface PCI Express x16
Temperature 63 °C
GPU Clock 580 MHz
Memory Clock 725 MHz
Driver version 6.14.13.783
BIOS Version 5.73.22.18.05
ROPs 8
Shaders Vertex 12/Pixel 125
Memory Type GDDR3
Memory 256 MB
Bus Width 64x2 (128 bit)
Pixel Fillrate 4.6 GPixels/s
Texture Fillrate 7.0 GTexels/s
Anti Aliasing Modes 1x2OGSS, 2x2OGSS, 4x4OGSS, 2xRGMS, 2xRGMS+5, 4xS, 6xS, 6x, 2x1OGSS, Gamma, 4xRGMS, new2 8xS, 16xS, 4xOGSS, Trans MS, Trans SS
Filtering Modes Bilinear, Trilinear, 16x Anisotropic
Noise Level Quiet
Max Power Draw 65 Watts
Count of performance levels : 1
Level 1 - "Perf Level 0"
Storage
Hard drives
HDS728080PLA380
Manufacturer Hitachi
Product Family Deskstar
Series Prefix Standard
Model Capacity For This Specific Drive 800GB
Heads 16
Cylinders 9,726
Tracks 2,480,130
Sectors 156,248,190
SATA type SATA-II 3.0Gb/s
Device type Fixed
ATA Standard ATA/ATAPI-7
Serial Number PFDHU0SYSREDKX
Firmware Version Number PF2OA63A
LBA Size 48-bit LBA
Power On Count 653 times
Power On Time 1996.0 days
Features S.M.A.R.T., APM, AAM, NCQ
Max. Transfer Mode SATA II 3.0Gb/s
Used Transfer Mode SATA II 3.0Gb/s
Interface SATA
Capacity 74 GB
Real size 80,000,000,000 bytes
RAID Type None
S.M.A.R.T
Status Good
Temperature 38 °C
Temperature Range OK (less than 50 °C)
S.M.A.R.T attributes
Attribute name Real value Current Worst Threshold Raw Value Status
01 Read Error Rate 0 100 100 16 0000000001 Good
02 Throughput Performance 213 158 158 50 00000000D5 Good
03 Spin-Up Time 11141303 ms 113 113 24 0000AA00B7 Good
04 Start/Stop Count 676 100 100 0 00000002A4 Good
05 Reallocated Sectors Count 2 100 100 5 0000000002 Good
07 Seek Error Rate 0 100 100 67 0000000000 Good
08 Seek Time Performance 28 142 142 20 000000001C Good
09 Power-On Hours (POH) 1996d 0h 94 94 0 000000BB20 Good
0A Spin Retry Count 0 100 100 60 0000000000 Good
0C Device Power Cycle Count 653 100 100 0 000000028D Good
C0 Power-off Retract Count 2,025 99 99 50 00000007E9 Good
C1 Load/Unload Cycle Count 2,025 99 99 50 00000007E9 Good
C2 Temperature 38 °C 144 144 0 00000E0026 Good
C4 Reallocation Event Count 2 100 100 0 0000000002 Good
C5 Current Pending Sector Count 0 100 100 0 0000000000 Good
C6 Uncorrectable Sector Count 0 100 100 0 0000000000 Good
C7 UltraDMA CRC Error Count 0 200 253 0 0000000000 Good
Partition 0
Partition ID Disk #0, Partition #0
Disk Letter C:
File System NTFS
Volume Serial Number A8A3A1DB
Size 74 GB
Used Space 13.7 GB (18%)
Free Space 60 GB (82%)
ST2000DM001-9YN164
Manufacturer Seagate
Heads 16
Cylinders 243,201
Tracks 62,016,255
Sectors 3,907,024,065
SATA type SATA-III 6.0Gb/s
Device type Fixed
ATA Standard ATA8-ACS
Serial Number Z1E1GDV7
Firmware Version Number CC4H
LBA Size 48-bit LBA
Power On Count 465 times
Power On Time 37.8 days
Speed 7200 RPM
Features S.M.A.R.T., APM, NCQ
Max. Transfer Mode SATA III 6.0Gb/s
Interface SATA
Capacity 1863 GB
Real size 2,000,398,934,016 bytes
RAID Type None
S.M.A.R.T
Status Good
Temperature 36 °C
01 Read Error Rate 0 119 99 6 000CA733E0 Good
03 Spin-Up Time 0 ms 94 94 0 0000000000 Good
04 Start/Stop Count 403 100 100 20 0000000193 Good
05 Reallocated Sectors Count 0 100 100 36 0000000000 Good
07 Seek Error Rate 0 72 60 30 0000EFED4A Good
09 Power-On Hours (POH) 37d 19h 99 99 0 000000038B Good
0A Spin Retry Count 0 100 100 97 0000000000 Good
0C Device Power Cycle Count 465 100 100 20 00000001D1 Good
B7 SATA Downshift Error Count 0 100 100 0 0000000000 Good
B8 End-to-End error / IOEDC 0 100 100 99 0000000000 Good
BB Reported Uncorrectable Errors 0 100 100 0 0000000000 Good
BC Command Timeout 4,295,032,833 100 99 0 0000010001 Good
BD High Fly Writes (WDC) 0 100 100 0 0000000000 Good
BE Airflow Temperature 36 °C 64 61 45 0024230024 Good
BF G-sense error rate 0 100 100 0 0000000000 Good
C0 Power-off Retract Count 63 100 100 0 000000003F Good
C1 Load/Unload Cycle Count 7,550 97 97 0 0000001D7E Good
C2 Temperature 36 °C 36 40 0 0000000024 Good
C7 UltraDMA CRC Error Count 0 200 200 0 0000000000 Good
F0 Head Flying Hours 27d 5h 100 253 0 000000028D Good
F1 Total LBAs Written 44,464,239,593 100 253 0 005A4673E9 Good
F2 Total LBAs Read 201,328,274,191 100 253 0 00E019AB0F Good
Partition 0
Partition ID Disk #1, Partition #0
Disk Letter D:
File System NTFS
Volume Serial Number E023E976
Size 1863 GB
Used Space 186 GB (10%)
Free Space 1676 GB (90%)
Flash drives
USB Device
Interface USB
Capacity 7.46 GB
Real size 8,006,074,368 bytes
RAID Type None
S.M.A.R.T
S.M.A.R.T not supported
Partition 0
Partition ID Disk #2, Partition #0
Disk Letter F:
File System FAT32
Volume Serial Number E63C3CAA
Size 7.44 GB
Used Space 3.96 GB (53%)
Free Space 3.48 GB (47%)
Audio
Peripherals
HID Keyboard Device
Device Kind Keyboard
Device Name HID Keyboard Device
Vendor Logitech
Location Location 0
Driver
HID-compliant mouse
Device Kind Mouse
Device Name HID-compliant mouse
Vendor Logitech
Location Location 0
Driver
Printers
Microsoft XPS Document Writer (Default Printer)
Printer Port XPSPort:
Print Processor WinPrint
Availability Always
Priority 1
Duplex None
Print Quality 600 * 600 dpi Color
Status Unknown
Driver
will Avid update the 11 rack drivers to work with 12 ddropski Eleven Rack 12 11-15-2016 06:07 AM
Eleven rack updater -can't find drivers - update firmware trouble! Sep Eleven Rack 3 11-06-2015 08:02 AM
Digi002 Rack Firmware update w/o internet? broodley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-21-2003 04:25 PM
Digi002 Rack shipping with Digi002 plugin pack? Vaphoron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-22-2003 02:38 AM
