h/w buffer HELP
Im doing a project in school tomorrow!using my avid mbox and PT9. All of the sudden its saying my h/w buffer size is not supported and i need to change it. (which has never happend it always works as soon as i plug it in.) So i go to Playback Engine to change it, and the drop down box isnt even their! im lost! My current h/w size is 44.1kHz default i guess. Help me ASAP!
Re: h/w buffer HELP
What is it saying exactly----are you sure it's not that the audio is playing, it stops, and says you need to change the buffer settings?
Re: h/w buffer HELP
[QUOTE=tystick420;1904521 My current h/w size is 44.1kHz default i guess. [/QUOTE]
"44.1kHz" is a sample rate and not a hardware buffer setting. Go to "Setup" - "Playback Engine" and you should have a drop down selection for "HW Buffer." The choices should be 32, 64, 128. 256. 512, and 1024 samples. Normally you select a larger H/W Buffer to give your system adequate time to process the audio data. The preferred setting is to use the lowest setting without problems for tracking (limited by hardware) and the highest setting when mixing. You should also make sure that you have done all the other system tweaks to make your system perform optimally for Protools (not the same as optimally for a personal computer). These include turning off Wi-fi, bluetooth, anti-virus software and recording to a physically separate hard drive (not your OS drive)
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Re: h/w buffer HELP
I fell asleep late last night giving up cuz it wouldn't work, accidentally left my mbox plugged in.oops! woke up at 7 and it was working didnt do a damn thing. idfk. But the thing was that when i go to Playback Engine to change the sample rate the drop down box wasnt even their. now it is. i messed with it for hrs last night and went to sleep with it not working... PT likes to give me a hard time From time to time
Re: h/w buffer HELP
Good to hear it fixed itself. It might be a good time to make a drive image of your working system so you can always come back to it when needed.
Obsidian Dragon
ASIO client buffer and PT playback buffer mismatch? | ChuckS | Windows | 1 | 01-16-2011 11:04 AM |
Increase Buffer Size Error (Buffer at MAX) ??? | PoPimp3069 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 03-29-2010 02:24 PM |
6086, buffer underflow, hw buffer size and other errors on i7 | rhythmtechnologies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 05-30-2009 08:36 AM |
Buffer error 9129 & 9093 when turn down buffer | StackLife06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-01-2006 09:34 PM |
Hardware buffer size in relation to DAE buffer | sricabla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-04-2006 10:30 AM |
