mastering in protools
my question is what is the best way to create a master session? should I bounce to disk multi mono ,then create a new session and import songs to that session. and do I dither before mastering? or should I record everything to a new track, then import that to a new session. thanks Kevin
Re: mastering in protools
Best way? I don't know.
My way? I bounce sessions to 24 bit stereo interleaved, no plugs on the master bus, plenty of headroom. I import the 24 bit files into a new session, add mastering plugs to the master bus in that session, and rebounce them one at a time to 16 bit (with dither last in the plug-in chain on the master bus).
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
I hear ya. Thats what I was gonna do,but I'm not sure if thats the best way? thanks for reply.
Thanks.
how u doin ?no when I bounce back in to same session I use multi mono
Is that better than recording the project in to a stereo trax then importing that trax to a new session?
Since when? I import stereo interleaved files without issue. In any case, I prefer to master in Wavelab for several reasons, not the least of which is fast rendering(no real-time bounce required) and the analysis tools are really great. I would bet the $99 Essentials version would be nice for getting a taste of it(without dropping $499). Version 7 also runs on Macs if anyone cares
Can you use all your RTAS plugs in Wavelabs? My apologies, I'm not really up with mastering software. Tried using T-racks, but ended up going back to a dedicated mastering session in PT.
I do the same as above. Bounce to stereo, import into the mastering session, then add plugs, and bounce one at a time. I like how you can master entire albums with T-Racks though...as really thats how it should be done. It would be one hell of a long session if you did a whole album in PT that way though.
- Macbook Pro 2.5Ghz, 4gb RAM, 320Gb HD @ 7200RPM - 2 x Profire 2626 - PT8.0.1 M-powered - Yamaha HS80M - Axiom Pro 49 - 500GB Sarotech Hardbox external HDD plugged through express card, FW800 - Waves Gold bundle, L3-16, Eddie Kramer - 2 x Coles 4038, Royer 121, 2 x Shinybox MXL, 4 x SM57, 3 x SM58, AKG D112, SM81, Shure 16A, sE 2000, 3 x Audix D2 |
PT Lover makes a good point that I had not thought about. The one time I bounced out to separate L&R files was a nightmare to get aligned in WaveLab for mastering(for sure it was my lack of knowledge there). As to the plugins question, WaveLab uses VST plugins, so none of your Pro Tools plugins will be available. Many(most) 3rd party plugins can be installed with both VST and RTAS versions(waves is one brand that works great on both Pro Tools and WaveLab) and WaveLab includes some of its own. Mastering and recording/mixing really are 2 different animals, and while I CAN master in PT, doing it in WaveLab(or any program designed for this) just works much better for 95% of the time. Plus, WaveLab is a good CD authoring program (something the PT does not do at all, and iTunes stinks at)
How would you do this now?!!! - Mastering a CD in Protools | Taffypro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-31-2009 05:31 PM |
Mastering in Protools | whateverwrks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-23-2008 12:15 PM |
mastering in Protools LE 6.0 | booboocakesjones | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-02-2004 06:35 AM |
mastering in Protools LE 6.0 | booboocakesjones | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-28-2004 01:46 PM |
How is mastering done in the world of Protools? | CB Boeger | General Discussion | 3 | 05-21-2002 10:06 AM |
