Old 11-21-2010, 12:54 PM
davidlustrup davidlustrup is offline
Default Quiet Please!
ok, im looking for a way to make my pc as quiet as possible...
anyone have any suggestions for quiet cpu coolers ( non liquid) and quiet chassis fans?
quiet power supplies?
im using a cooler master cosmos case with sound deadning side plates as it is but its still too loud and i wanna make it as quiet as possible without risking airflow and overheating issues
Win 7 64 bit
AMD Phenom(tm) II X4 965 Processor
Mainboard : Asus M4A78T-E
BIOS : AMI 2402 01/05/2010
Chipset AMD RS780 Host Bridge
Memory 6 gigs ddr3 1600mhz
Memory OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) X 3 for 6 gigs
Video Adapter : ATI Radeon HD 4870 X2
Western Digital Black 1TB, SATA300,7200 rpm 64MB Cache 932GB For PT
WDC 500.1GB, SATA300,7200rpm, NCQ, 16MB Cache For Recording
http://www.vampirefreaks.com/dawnofblack
Old 11-21-2010, 01:03 PM
sunburst79 sunburst79 is offline
Default Re: Quiet Please!
Nexus 80MM fans.
Nexus 120mm fans, Scythe 600-800RPM 120mm fans (forget the series name), Noctua 120mm fans.
Corsair and Seasonic are quiet PSUs, Nexus also.
Lots of MASSIVE CPU coolers out there. I'm not sure whats currently the quiet cooling king. Look for one that takes a standard 120mm fan so you can use the fan of your choice.
Check a site called Silent PC Review (SPR) for excellent advice.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 11-21-2010, 01:12 PM
Arctic Cooling and Zalmann make some quiet cpu coolers. Fanless video cards solve a lot of noise as well. What PSU do you have? Those with the bigger fans tend to make less noise(fan turns slower and quieter). Also, try the rubbery mounts for PSU and hard drives. Another thing that helped me was to move the tower away from the desk with long cables(like 10 footers) and stick the case in a wooden case(nice oak plywood with edging and a clear poly finish) with foam on all sides, that extended out the back(creating a foam tunnel that stuck out a foot past the tower). Of course, I put my DVD drive on the desktop(external case) for convenience. I could track vocals right behind my chair without noise issues.
Old 11-21-2010, 01:19 PM
thanks guys ill look into those names for sure...i had one guy tell me to use a gate...but to me thats not doing it right, although a gate IS closed untill the vocal starts, WHILE the vocal is being sung....its open...and all the room noise is comming in WITH the vocal...so when i compress/limit etc etc...that noise will be getting amplfied as well, so gating doesnt seem to be the right thing to do to me. id rather have no excess junk going in in the first place =)
with that box you built, your not getting any overheating issues by putting that pc in a box? just curious
Win 7 64 bit
Old 11-26-2010, 11:43 AM
EGS's Avatar
EGS EGS is offline
I recently built a new Win7 system, and it runs super-quiet. This link lists the CPU cooler, (fanless) video card, and PSU that I used:
http://duc.avid.com/showthread.php?t=279758
Also, at Micro Center I found some really quiet case fans with rubber mounting grommets, available in both 80 and 120mm sizes:
http://www.microcenter.com/single_pr...uct_id=0276339
Hope this helps !!!
Click for audio/video demo
Click for resume
Old 11-26-2010, 02:46 PM
ldeadhead ldeadhead is offline
A Titan Fenrir cooler, albeit massive, silent. An alternative, and much less expensive, would be an Artic Freezer Cooler, perhaps the 7 Pro.
A Xigmatek PSU, again very quiet or a less expensive option, a XFX PSU. Antec also known for some fairly quiet models.
Why the Crossfire set up with the Radeons? Is it a requirement for your needs? A single, modern, 5000 or 6000 series AMD / ATI card would probably match the paired 4000's in frame-rate etc. and be a lot quieter. As has been said previously, why not go fan-less.
Variable speed case fans might be the way. It you need to get rid of excessive heat then turn the fan speed up - not a likely scenario whilst recording vocals.
The mounting of drives in 'quiet' chassis has worked for me. If we are really cutting back on the dB then your Western Digital is possibly louder than a Seagate Barracuda.
Reading the small print on dB output for all of the components is, IMHO, the way to go ...
Best of luck
Old 11-26-2010, 06:57 PM
DaveBCC DaveBCC is offline
For a while people were all jazzed about water cooling, but I don't read so much about that anymore.
In my bedroom project studio, and after going through a couple of passes with quiet fans, acoustically treated cases, cabinets with more fans, etc., I finally just moved mine into an adjacent closet, drywalled a 4"x 4" port through the wall near the corner floor for cables, stuffed it with foam, put my mic stand container in front of it, closed the door, and couldn't be happier ... you'd never know there was a computer anywhere around there.
As long as I don't get the burning desire to record in the closet, I can't think of a better solution.
Old 11-26-2010, 07:13 PM
See and I want to turn my closet into a vocal booth but its already full of gear
Scott
Core 2 Specs Page
Old 11-26-2010, 08:46 PM
In any case DO NOT use a gate.
Old 11-27-2010, 08:13 AM
MikeX MikeX is offline
PC Power & Cooling make a fanless PSU.. very high quality and 700W.
Also.. Zalman makes great CPU coolers as well.
My suggestion is also enabling fan control, you can even buy a fan controller that will change the speed of the fans depending on temperature. It's what I'm doing right now and works great.
I have that case as well.. I ditched it for a Gator 4U and a 4U rackmount case because I'm mobile... but that case ROCKS if you don't move it..
Pro tools HD 9 - HD3 setup w/96 IO
AMD 3.81GHZ Phenom II X6 CPU - 8GB Ram - Win7 64-bit
Focusrite Voicemaster Pro
Presonus StudioLive 16 Channel Mixer
Digimax D8 8-Channel Preamp
Command 8
Vocal and Instrument Recording/Live PTHD Mixing
Quiet PC eye2iRt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-08-2003 08:55 PM
quiet pc wesside General Discussion 0 10-07-2003 11:49 AM
how quiet is the G5? orangerec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 24 09-30-2003 08:35 AM
How quiet is the Magma Quiet 4 slot Chassis? Walling1 Pro Tools TDM Systems (Mac) 3 07-15-2002 10:37 AM
very quiet Chris Lambrechts ProControl, Control|24, Command|8 4 06-14-2002 03:24 PM
