Re: HD Native on Core Cards
So you think the HD Native card is vastly different to a TDM card in its design? So different that if Avid wanted to, they could not implement a software mixer using TDM cards? I find that hard to believe, and in fact would go so far as to say it's rubbish...
You can use your 192 + HD Core card as an interface for third party DAWs, so there is no reason whatsoever that, if Avid wanted to, they could run Pro Tools Native using the TDM card as the interface. |
TDM does more than Native. It doesn't look like it now... because the current line of TDM cards are vastly underpowered compared to current native processing, but when the new TDM cards come out, it will all make sense. There will be no reason to run Native on a TDM card.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Like I said, I know the relative merits of TDM and Native.
I don't want to do it! But it would be better for users of say HD1, who feel that now Native would be more powerful; if they could run Native on their existing hardware. Like I said, you've missed the point of my post all along! :) |
Avid created HD|N to be an entirely separate solution from TDM. HD1 looks underpowered now only because of timing. Come another month or two... the tables will turn.
i will remove "hold fast baby hold fast" from my sig line. (at least for a day LOL)
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
The Pro Tools version that runs with Native is *exactly* the same as the HD version in functionality. The only difference being Native cannot run TDM plug-ins and HD is a tad bit faster as far as monitoring latencies go - and you can run TDM plug-ins with near-zero latency. HD systems are extremely unlikely to ever run the mixer on the CPU. The round trip latencies for doing so would completely dissolve any of the benefits of the near-zero latency monitoring capabilities of HD. |
Native means processing on the native CPU so, it would be easy to make the HD core card as a native input I/O card. We have already that feature with the core driver but it is limited to 8 I/O.
If you say that your PT HD Native card is handling the mix engine too, you are using the word "Native" in completely the wrong way.Totally wrong. I wouldn´t be surprised if the new HD Core TDM card looks pretty similar to the native card. I guess the native card is a crippled HD Core card based on the HUGE heat sink. Can someone remove the heatsink and check which SHARC CPU there is?
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
http://en.wikipedia.org/wiki/Field-p...ble_gate_array |
Which Mac Pro for HD Native? 2008 8 Core or 2009 Quad Core? | sws2h | Pro Tools 10 | 6 | 11-03-2011 03:23 PM |
What is the thermal output/heat load of HD core cards and process cards? | yosemitesam | Pro Tools TDM Systems (Mac) | 0 | 10-24-2011 02:39 PM |
prottols core cards mix core to hd pci to hd pcix to hd pce | Filmusic | Windows | 1 | 03-24-2011 04:24 PM |
Mac Pro Dual Quad core compatable with HD pci core & accell cards? | PT8716 | Pro Tools TDM Systems (Mac) | 3 | 06-28-2010 07:35 AM |
HELP!!! running 2 core cards on mix sys & lights on cards??? HELP!!! | A Spooner | Tips & Tricks | 6 | 07-08-2009 06:55 PM |
