Pro tools 12 midi in not working
Hello guys! Im a new user pro tools. I m using pro tools 12 with external midi sequencer Korg pa900 with usb midi cable. Well i hv a problem of midi in, midi out is working good but midi in signals are not receiving my pro tools. I checked with same driver on other daw softwares like fl studio and cubase. These two softwares are receiving signals and working, its mean my sequencer is sending signals well but pro tools in not working. Pls help me.
Win7 Pro tools 12 Amd phanom 4x 3.2 gh 6gb ram |
Re: Pro tools 12 midi in not working
To get midi INTO Pro Tools, you must setup your midi controller in the Midi Studio window(that's in Pro Tools, Setup>Midi>Midi Studio). Create a new "Instrument" and name it("Korg" would make sense). The next 2 settings for brand and model are NOT required(so if the Korg is not on the list, just leave that part blank). The next setting called Input Port is the crucial setting. Hopefully, when you open that selection, the Korg will show up(it might read something like Korg PA900 USB[Emulated], but as long as you see the Korg on the list, select it. If that's your only external midi device, leave the rest at the default settings and close the window.
MIDI not working in Pro Tools 11.0.1 | asaffulks | Pro Tools 11 | 19 | 10-15-2016 10:54 PM |
Midi not working in Pro Tools 11 | kg366 | Pro Tools 11 | 2 | 09-08-2015 06:45 PM |
Pro Tools 10 MIDI controller not working | PTMullen | Pro Tools 10 | 0 | 04-09-2015 01:40 PM |
Midi Control Not working in Pro tools 11.0.1 but works in pro tools 10.3.6??? | bleudog | Pro Tools 11 | 17 | 04-30-2014 03:13 PM |
Midi Not working on Pro Tools 8 | Tesar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-11-2009 10:50 AM |
